Question about Apple iPod MA446LL/A MP3 Player
IPod Video 5G shows lock, can't unlock
I have an iPod Video 5g that has the lock icon displayed and the hold switch has no effect on it whatsoever. I have 3 of these. I swapped the back from a working one and same problem. The problem seems to be on the logic board but I can't seem to locate the problem. I talked with Apple and they said it needed to be unlocked at the logic board. Anyone know exactly how that is accomplished?
I hit it hard on a table on the corner adjacent to the hold switch and it fixed. Keep in mind though my Ipod already has problems but I know its the logic board. I know how to fix these things but I was just fed up so I beat it on a table. You might try that.
Posted on Sep 12, 2010
  • 3 Answers
I had this same problem and tried everything posted on the internet to get it working. Nothing was working...
I had the harddrive replaced at some point but some internet ipod drive saver guys. Got it back working fine. Then my battery wouldn't stay charged very long, so I bought a replacement and swapped it myself. Worked fine initially but shortly after got the lock icon in the top left, regardless of the HOLD switch position.
After trying everything else, I opened the case again, and moved the switch on and off using the exposed connector on the inside rather than by the external part of the switch. While doing that, I instantly saw the screen light up on the table it was laying on. I turned it over and the lock was gone! So apparently, there must have been some issue with the HOLD switch that by moving from the inside was able to fix.
Posted on Sep 19, 2008
  • 33 Answers
Turn on the hold swich and turn it off, then press the Play/Pause button and the center button at the same time until it resets. This may fix your problem.
Posted on Jul 30, 2008
My ipod camera doesn't have the camera with the curved arrows to switch the camera view
Hi, What generation of iPod do you have? If you have 1G to 3G, you have no camera, on 4G you have one at the front and one at the back on the 5G, 64Go and 32Go versions have cameras on both sides and the 16Go iPod Touch 5G, there is only a camera at the front and none at the back. You could also try restoring from iTunes and see what happens.
Oct 28, 2013 | Apple iPod touch
NeI have a 3G iphone and want to know if a camera or vedio can be downloaded onto iPhone. taa
hi there its not actually possible to update to 4g or 5g as its a different circuit board and software and internal chips.
martyn
Apr 08, 2013 | Apple Iphone 16gb 3gs Ios 5wifi Facebook...
Iphone won't connect to Netgear R6200
Yeah that's a dual band router. Which means it operates on 2.4Ghz and 5Ghz. Sounds like some of your devices only work on the 2.4Ghz. So make sure it is enabled in the configuration.
This video will show you how to get to the config screen on your router.
Jan 27, 2013 | NetGear R6200 WiFi Router
How can i unlock my ipod nano 4GB
"Screen Lock" is provided by the iPod nano, iPod (5G), and subsequently released iPod models. Earlier iPods do not offer this feature.
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer . When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
May 18, 2010 | Apple iPod nano
I forgot my passcode for my ipod nano 2 gb. How do i unlock it with out plugging the ipod into the computer
reposting again..
How can i unlock my ipod 5g
to unlock the ipod you have to remember the password that is set. Unless it is a ipod that has a slide switch on the top or side. If you do not remember the password that is not a problem. Follow the steps that i have outlined below. If this does not completely help your situation please let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
May 05, 2010 | Apple iPod MA446LL/A MP3 Player
Unable to load videos
You could try Wondershare Video Converter Platinum, it could help you switch your videos to different formats between all popular Video formats ( AVI, MKV, MP4, WMV, FLV, MPEG etc.) that support all popular portable media players (such as Zune/Zune HD, iPod/iPhone and PSP) and the latest iPod Nano 5G, iPod Touch 3, iPhone 3GS/OS 3.1.
Jul 22, 2009 | Sylvania SMPK8854 Digital Media Player
Ipod is open but i cant play any song..its lock .What will I do?
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally--not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Jan 03, 2008 | Apple iPod nano
IPOD 5G CRASHED CAN'T BOOT DISK
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Oct 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
504 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
