Hi
Check
the back wall or floor of the freezer section for frost. Check the freezer (
evaporator) fan to see if it is running. Check the condenser coils under the
unit for blockage from dust. Check the condenser fan (under the unit) to see if
it is running.
If you have frost in the freezer there is a problem with the defrost system and
the freezer will start to warm eventually as well as the fresh food section. If
that is the problem you can check the defrost terminator, defrost heater/s, and
the defrost timer or adaptive defrost control If used on your unit or the main
control board if so equipped. These things usually require dismantling the
freezer and other areas of the refrigerator to be checked.
There
can be many factors for the no cooling factor: the condenser coils could be
blocked with dust, the condenser fan could be bad or stuck, the freezer fan
could be stuck or bed, the freezer coils could be blocked with frost because
the self-defrost system is not working or the compressor is not running because
of a bad relay etc.
Please
check this link to get a detailed idea about your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hi
Check
it is running.
There
of a bad relay etc.
Please
Please
Hi
Check
it is running.
There
of a bad relay etc.
Please
Please
Thank you for contacting fixya.com.
Check the condenser under the refrigerator is clogged with lint. Make sure that the condenser fan underneath the fridge is running properly. You can get to it through the back. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost thermostat, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Check the condenser under the refrigerator is clogged with lint. Make sure that the condenser fan underneath the fridge is running properly. You can get to it through the back. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Please get back to us if you have further query else please accept the suggestion.
Hi, Thank you for contacting fixya.com. Check the condenser under the refrigerator is clogged with lint. Make sure that the condenser fan underneath the fridge is running properly. You can get to it through the back. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost thermostat, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again. Also check this link for your problem:- http://www.arxmanhome.com/how-to-repair-refrigerator-defrost-problems/
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
