Question about Minolta Office Equipment & Supplies
Minolta Di 3510f
Display says please wait won't come ready. Try replacing the nix card no change in symptom
  • Kim Krell Jul 14, 2008
    We had no error code, we are very familar with fuser problems. The fuser was heating up (hot to the touch).
    We did finally get the machine to give an "ABORT" error by pressing the reset button on the main board. It gave a code of "0X00e00422" then we looked at the network interface. The machine comes ready and makes a copy if we remove the scan and memory card. With either card installed we go back to the original symtom. Now we dont know if they are both bad (hard to belive) If you can help with what we have now discovered???? We wonder if the board the scan/memory boards plug into is bad??? Thanks for your help, Krell222
  • Anonymous Mar 27, 2014
    minolta di 550
  • 446 Answers
What do you mean NIX? or do you mean NIC?, please wait message could cause by many issue it could be the temperature issue, machine need to reach a certain level of temp in order for the machine to be ready it could be from you termistor or the fusing lamp might not be working at all
Posted on Jul 14, 2008
  • ariel santos
    ariel santos Jul 14, 2008
    it can be tricky or you may be having a corrupted Printer scanner kit, pls make sure that you have for the right model otherwise this error message is a real indicator of incompatibility whether from the memory chip or from the board itself.
    usually the memory card is the cause of this, try replacing this first. in my experienced it is unusual that they can both go wrong unless they are not for this model, is the machine recognized the presence of the Printer/Scanner ? if it doesn't then the problem could be from your Card...and not from the memory chip
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
What if my nokia 5130 xpressMusic won't open because of too much sms?
remove your sim card. try using different sim card just to open the phone. then set the default storage for the messages to the memory card. then return your original sim card. when you open inbox you will notice all messages is gone. then set again the default storage of messages to the sim card to bring back your messages.
May 09, 2011 | Computers & Internet
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
I have a samsung rear projection tv manufactured 2/2003. model #PCL 5415R. PROBLEM: convergence Need part number of convergence card and where to purchase it.
Please save your money and get this unit repaired, just because the set displays a "Convergence"SYMPTOM does NOT mean that changing that board will fix the unit, 9/10 it will NOT. I see this time and time again in the shop whereby people think they can fix their TV whatever, and mistake the SYMPTOM, for the cause and try to fix, usually unsuccessfully at that. The CAUSE must be repaired as well as the symptom, simply replacing a board will seldom "Repair" anything as the original fault that caused the symptom still has NOT been fixed. Please get a "Quote" they are free and at least then you will know what is the problem, even if you decide NOT to repair you have that information.Also one MUST have a Service Manual to be able to order the parts as without this number you simply cannot get parts.. it is that simple.
Mar 17, 2010 | Samsung PCL5415R TV
Printer does'nt initialize
This could be a Jetdirect network card fault. Remove the card and power the printer on. If it powers up and goes ready then power it off again, refit the card and try again.Sometime reseating the jetdirect card will sort this problem If it doesn't work, then i recommend replacing the jetdirect netwok card.
Oct 13, 2009 | HP LaserJet 4100dtn Printer
Video looks like you are looking through a screen door. The video stays on screen, but the screen symptom comes and goes.
screen door syptom sounds like a scale/descale issue - try a different player and change scaling/aspect ratio settings on the display and the player
Sep 01, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Thinkpad T21 won't boot - fast ticking sound
i thnk maybe you ram is the culprit try to place the ram firmly in th socket to start your Thinkpad.... the beeps represent a hardware fault
you might have to count the beeps and tell me how many are exactly there?
Jun 07, 2009 | Lenovo ThinkPad T21 2647 Notebook
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
129 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
