Question about Canon CLC 1120 Color Copier
Scan to folder
When I scan to folder on server, I get the following message
tx image set not to display
Why and what does this mean?
  • 67 Answers
You need to set it up on your server why dont you scan to email talk to your it guys maybe the do not want people to scan to folder
Posted on Jul 25, 2008
Hi, i got a ir3580 cannon copier and it doesnt give me an option to scan to email, it shows the message tx image set not to display..can anyone help please !
If you don't have the send button then it wont work
2sd1jiwyhgy0enk6bz++uuv7u7uo++889133+uec2opd8bcahhpotghfxcig6gnokodtwmlvknn8bpn818thyfuya9kvjsojqbav1555f8pn4qurspzoduaaaaasuvork5cyii=Make sure you have the send button available on the canon device as shown above, and fully networked, if so follow instructions below
setting up the device for scan to e-mail
1.select * head > SYSTEM SETTINGS > NETWORK SETTINGS > E-MAIL SETTINGS. You may need to scroll down the menu to find the e-mail settings
2. Fill in the required fields, SMTP or POP settings
Someone with a little IT background would help
images?q=tbn:and9gcqwahyvwfq_dazga7r3wmakfzbd5p63hemso8op0xszyghtsmvuiq
The e-mail address is for the recipient so they know where the scan-e-mail come from e.g canonscan@yourbuisnessname.com
The server address settings are important.
3.Go back to send screen to add e-mail address and test
Restart device may help sometime after changing device settings:) Good Luck
Apr 03, 2013 | Cannon Office Equipment & Supplies
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Oct 07, 2011 | Konica Minolta Konica Bizhub C353 Drum...
TX IMAGE SET NOT TO DISPLAY
enable tx display at additional function button.
Aug 07, 2009 | Canon CLC 1120 Color Copier
Tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
May 05, 2009 | Canon imageRUNNER C3200 Copier
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
Currently working on XEROX WorkCentre Pro 55. Want to scan documents to my computer from newwork printer. What do I need to set up in order to utilize this feature. I tried scanning to a programed user...
> Support & Drivers > WorkCentre Pro 55 Support > Search Results Solution: Set up Network Scanning Using Server Message Block (SMB) Filing With CentreWare Network Scanning Software v 5.5x bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Prerequisites:
  • The printer must be connected to the network.
  • The IP Address of the printer is required, and the HTTP option must be enabled on the printer. If you do not know the IP Address, or whether HTTP is enabled, print a Configuration Report. See the Related Items below for additional information. If you do not have this information or the printer is not configured correctly, contact your System Administrator for assistance.
  • A user account for the scanner to login to the scan server must be created (account needs full control access rights). The user needs to be a local user on the workstation and not a domain user.
    NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
  • CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
  1. Click on [Start], point to [Programs], select [Xerox CentreWare], and then select [Add Network Scanner]. The Add Network Scanner Wizard window will be displayed.
  2. Click on the [Enable a new Xerox System Scanner for network scanning and associate it with a scan server] radio button, and then click [Next].
  3. Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
  4. If Specific IP Address is selected, an IP Address field will be displayed. Enter the IP Address of the printer in the field, click [Next], and then skip to step 7.
  5. If Specific TCP/IP Hostname is selected, a Hostname field will be displayed. Enter the printer’s TCP/IP hostname in the field, and then click [Next].
    NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
  6. If the printer has been configured for Scan to File, a window will be displayed with a 'This device has already been configured for network scanning. Continuing will overwrite its current configuration. Do you want to continue?' message. Click on [Yes].
  7. The Enter Password window will be displayed. Enter your system password in the field provided, and then click [OK]. The Server Type (Filing Protocol) window will be displayed.
    NOTE: The initial system password at machine install is 1111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  8. From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
  9. Click on the [Browse] button located below the Location (\\Server\ShareName\Path) field. The Choose Location – Windows (SMB) window will be displayed.
  10. Browse to the server and then to the Scan folder where the CentreWare scanning folders will be installed, and click [OK]. The Location field will be displayed with the scan server name and the path to the shared scan folder.
  11. Click [Next]. The Xerox System Login Name window will be displayed.
  12. Enter the scan user name and password (this is the user account the printer will use to login to the server share) in the fields provided, and then click [Next]. The Distribution Server window will be displayed.
  13. Do not make any changes. Click [Next].
  14. Click on [Manage User Templates]. The Manage User Templates window will be displayed.
  15. Click on [Modify Template List] to begin selecting template users for this scan server installation. The Modify Template List window will be displayed.
  16. Make a selection from the list of Users and Groups, and then click on [Add] to create a scan folder and template for the selected user or all members of a selected group. If necessary, repeat this step to add additional users or groups.
  17. When you have finished, click [OK] twice. The Finish window will be displayed.
  18. Click on [Finish] to upload the scan settings to the printer. The Add Network Scanner Wizard window will close when the settings have been uploaded.
Jun 02, 2008 | Xerox Office Equipment & Supplies
RE : Xerox Work Centre M128 016-782
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
May 19, 2008 | Xerox WorkCentre M128 Copier
Microsoft Digital Image Suite 2006 Anniversary Edition
You can add all your pictures to the program's library which should eliminate that problem...
To scan for pictures on your computer:
1. On Digital Image Library’s File menu, click Add Pictures to Library.
The Add Pictures to Library window opens. The folders already cataloged
in Digital Image Library are displayed.
2. Click Scan.
3. In the Beginning Picture Scan dialog box, click OK.
The hard disk drive is scanned, and the folders containing pictures are
displayed.
4. Clear the check box next to any folder you don’t want to add.
5. Click OK, and then click Done.
Hope this will FixYa!!!
Dec 10, 2007 | Adobe Photoshop 7.0 for PC
Help with scanning on mour Ricoh Aficia 2035.
Since this is a  network printer, you can scan to folder,FTP site or email. alot will depend on your network enviroment. SMB is the simplest. The folder you are scanning to need permission to write to the folder. If you have email you need to enter your smtp server IP address in the user tools and an senders email address. the manuals with the copier will help or download them.
Oct 12, 2007 | Office Equipment & Supplies
Canon CLC 1120 Color Copier Logo
1,335 people viewed this question
old marine
old marine
