PICTURE IN PICTURE
I AM BUYING A SAMSUNG LN32A650 WITH "PICTURE IN PICTURE" FEATURE. HOW DO I KNOW I CAN GET IT TO WORK WITH MY CABLE COMPANY FEED?
    Genius:
  • Televison & ... Master
  • 1,689 Answers
If the set has two tuners, you can put two cable feeds on it. You simply use a splitter on the cable feed to have two feeds from the same cable feed.
If you are using a decoder, you will need a separate decoder for each video/audio input to the TV set. The exception would be a dual tuner decoder with independent outputs.
Jerry G.
Posted on Jul 11, 2008
Samsung led tv 5003 remote channel selector not working, must use cable company remote. Volume only works on samsung remote.
The cable company remote will have under settings a program code function for the remote. Setting the Samsung code will enable the cable remote to adjust the volume. Many TVs have more than one code. You may need to try several to get the right one.
the attached images are examples of this process. Your remote supplied from the cable provider will have its own unique process. Consult the info supplied with the remote. Access the help feature available with some cable services. Your cable provider may have the help function available on their Website.
Hope this helps?
Sep 28, 2016 | Samsung Televison & Video
I want to buy a cell phone, model is Samsung Champ C3303 with VGA cam. Its features is showing connectivity option, but i want to know that wether photos clicked with VGA cam can be transferred to PC or...
Yes, you can. If there is a cable included you can transfer using the USB Mass Storage mode.
If there is no cable, you can take out the memory card and insert it in a card reader so you can transfer your pictures to your computer.
Mar 09, 2011 | Cell Phones
My samsung A767 wont send picture messages anymore. i pay 60 per month for unlimited talk and text and i dont know itss myplan or my phone. it used to and now it just wont do it. it says "network...
You probably do not have MMS (multimedia messaging) support with your plan. Call your cell phone company to confirm you have this feature.
Feb 28, 2011 | Samsung Cell Phones
Green Picture
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
May 27, 2010 | Samsung HCN4226W 42" Rear Projection...
I have a black screen. Cable company says I have
This is a common problem with Cable companies when they update their firmware. This makes the two incompatible. You can try going onto www.samsung.com and look for firmware updates for your model. Follow the instructions provided. If this does not work then you have a bad cable box. Cables companies are notorious for blaming the tv. Don't let them fool you. Stand your ground and insist on them correcting the problem.
Apr 15, 2010 | Samsung LN-T3253H 32 in. LCD Television
I cannot get dvd feed to tv when I connect my jvc
I work for a cable company that has this exact cable box. in our system we choose not to actvate this option. cable companys go to motorola and give them the exact features that they want the box to perform. most cable companys won't have that feature added mainly 1 due to cost and 2 if you have that type of box it probably has on demand available, so they want you to rent a movie then to play it on dvd.in my opinion straight to the tv is better anyway, the less devices you run the video signal through the less problems you will have . all those ports on the back of the box is standard for the 6412, but are not always actvated.
Feb 21, 2009 | Arris DCT2608
Fried Cable Box and TV not working
hi first call you cable company and let them that your cable box cought firer then call samsung cause you have a year if anything happens just know that you may have to pay for repairs
Jan 09, 2009 | Samsung LN52A550 LCD TV
Connection between Samsung 46" LCD / Samsung Home Theater System &Tivo
None of the cables you mention are HD. Does your box have a HDMI out? If it does, an HDMI cable is what you need if your tv has an HDMI input jack.
May 13, 2008 | Televison & Video
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
Top Televison & Video Experts
