Question about Karcher 2500 PSI Pressure Washer
Tecumseh 6hp engine
Working on neighbors power washer to get it to run I took off & cleaned carborator? I think I have the linkages reversed to the throttle plate because it runs ok if I hold the throttle open. There is a lever from the governor with a couple of bends so it could be reversed. One wire linkage to it with bends to get out of the way of a spring on the other linkage. Also, the lever on the governor is attacned to another that could be flopped 180 degrees. So where can I get a picture that shows the 2 holes of throttle, 2 wire links one with a spring, 2 holes on the governor lever, that levers orientation, and the lever its attached to position forward or reverse. Karcher has changed to Honda, tech help said go look at one in store, 2 places they recommend don't sell Karcher any more. Tecumseh online has the owner manual but no details of this area. Any ideas where to get the info i need. Thanks
I have a 6hp tecumseh mower. "Centura Le". I prime it it runs..stop priming and it dies. I think it needs a new fuel pump/or filter. I can't locate on mower, will you advise?
Thank you
Posted on Jul 28, 2009
  • 33 Answers
Well no matter which way you turn that little linkage rod it either pushes or pulls. the bends are put there to keep it from hanging up on other things such as springs. try reversing the rod .the holes are a matter of opening the throttle should be 2 or 3 holes on one side of flat plate of stem for throttle plate. put the rod in the one that when in full open pushes the butterfly all the way open on the throttle.. also go to jacks small engines .com and select the motor type and just look at the schematic of the carb. you'll have to sign as a member and all that hooey but it don't cost nothing. just follow directions is all.
Posted on Apr 21, 2009
I have a Robin eh 34 engine in a Simpson power washer. The engine starts and runs but wont rev much past a fast idle. Carb has been cleaned thoroughly. gas is fresh. Suggestions
Butch if carb was good and clean and linkages were re installed properly including governor, it is possible the throttle tab/lever (what linkage hooks to) is loose on the shaft that opens the throttle butter fly. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY Tecumseh Snowblower Carburetor Throttle Shaft Lever Repair PART 1
Apr 13, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
How do i hook up the throttle cable on a 6hp tecumseh go cart motor
That depends on the routing of the cable.generic questions will usually get you a generic answer. good luck.should be some sort of linkage by the carb with a spring return to move the throttle to the idle position.make sure you dont screw this part up or you might have a nasty surprise when you go to take your foot off the throttle and you have a run away.
Jul 28, 2014 | Garden
I am looking for a manual for my 1980 troy-Bilt rotiller tecumseh HH60-1c5106f engine
check with a small engine shop they should be able to help
Jul 07, 2012 | Garden
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
OK i have a 91 honda civic hatchback and the engine was rebilt..it runs fine...however when i start it cranks for awhile before it starts...the starter and battery are fine however the carborator sticks...
That flap is automatic the choke. Not the throttle. Cleaning it should restore normal operation. Avoid spray plastic parts if there is any such as plastic bushing used in carburator linkage, other than that I cant think of any bigger underlying problem. Avoid prolonged high speed on rebuilt engines untill its broken in(500 miles)
Aug 11, 2009 | 1991 Honda Civic
Karcher 2500 PSI Pressure Washer Logo
2,287 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
