Question about Dell Inspiron 1000 Notebook
XP OPERATING SYSTEM
MY LAPTOP WILL BOOT UP TO "WELCOME" WHEN TURNED ON.
TO TURN OFF, NEED TO HOLD POWER BUTTON.
CANNOT GET PAST THE WELCOME ON SCREEN. HAVE TRIED SAFE MODE AND GET THE SAME "WELCOME". AM TO A POINT WHERE I MAY HAVE TO REFORMAT HARD DRIVE??
HAVE GONE TO DIAGNOSTIC MODE AND ALL SYSTEMS PASS.
ANY SUGGESTIONS??
HENRY J COOK cook1234@comcast.net
    Genius:
  • 2,028 Answers
First try a system repair with your operating system disc. If you have any issues during the repair, then reformat and reload the operating system.
Posted on Jul 11, 2008
I need the unlock password of BOSS os to unlock my laptop screen
Which Password? Bios Password?Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista?Windows 7?OK,if you are running Windows 7, Microsoft tightened security on it so you've gotto have a password reset disk which 99% of the people who own laptops withwindows 7 fail to do. It should be one of the first things you do whenyou buy the laptop. Otherwise, you're faced with reinstalling theOperating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator(hopefully you didn't put a password on it and forgot it too). Once thedesktop appears it will look different, the screen will be darker and the iconsbigger, but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Jun 08, 2012 | Lenovo Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
How do i install operating system with external dvd
Hi
How to Install Windows XP on a Thinkpad T20
The Thinkpad T20 is a laptop computer from IBM designed for business use. This computer comes with the Windows XP operating system and--if necessary--can be reloaded with the operating system. All you need to perform this operation is the installation disc for Windows XP and a valid product key. This product key can be found on the bottom of the computer or with the documents included with the machine (if Windows XP was pre-installed on the computer).
Windows XP CDProduct key
1 Turn on your T20 laptop computer and press the blue "ThinkVantage" button.
2 Scroll through the options and select the option to boot from your T20's CD/DVD drive.
3 Press the "Enter" key at the welcome window and press the "F8" key once you have read (and agreed to) the license terms for installing the software.
4 Select the drive on which you want to install Windows XP and press the "C" button, followed by the "Enter" button.
5 Press the "Enter" button again to start the installation process. When prompted, enter the product key for Windows XP. Once the setup finishes, you can use the computer.
Dec 26, 2011 | IBM ThinkPad T20 2647 Notebook
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
The laptop won't load past the welcome screen. I can get it to start up, and go to a start in safe mode etc. but it won't load past the welcome screen.
Your computer is experiencing a no boot problem which means that the operating system is corrupted. You can do a start up repair to fix the computer but if it won't fix it then that's the time that you need to reinstall the whole operating system.
It could have been very helpful if you provided us with your operating system so that we can provide you with the exact troubleshooting. However, I just presume that you are using windows VISTA or Windows 7. However, this troubleshooting also works with windows XP.
Before you start the start up repair. You need the Operating System Installation disc from Microsoft.
1. Insert the disc in the dvd/cd drive.
2. Restart the computer.
3. Once you see the "press any key to boot to cd" message. Press any key.
4. It will bring you to a page where it will ask you to INSTALL or to REPAIR. Just click on repair.
5. It might ask you to load the drivers. Just click ok or next.
6. Follow the on-screen instructions.
However, if start up repair won't fix the problem, Clean Reinstallation is the next step. Clean reinstallation will delete everything in your computer including the files, pictures, etc. that you have saved. But you cannot really access them anymore since the computer won't boot up.
I'm am providing you with the links to the tutorial on how to reinstall the operating system.
1. WINDOWS XP REINSTALLATION TUTORIAL
2. Windows 7 Reinstallation Tutorial
3. Windows Vista Installation Guide
I hope this helps. Thank you for using fixya.
carloadrian
Feb 03, 2011 | Gateway M-7315U Notebook
Computer wont reboot
The issue is due to presents of earlier operating system files which are avoiding you to reinstall the os.
At this point I recommend you to clean the hard disk and then try for fresh installation. However, I am providing you the steps below:
Perform the steps provided in the below web site and then perform the Reinstall process
http://killdisk.com/downloadfree.htm
NOTE: The URL above will take you to a non HP Web site. HP does
not control and is not responsible for information outside
of the HP Web site.
After performing the complete format of Hard Drive, Reinstall the Windows XP.
To reinstall the operating system, follow the steps below:
1. Ensure that the CD-ROM is connected to the notebook.
2. Turn on the notebook.
3. Immediately insert the operating system CD into the CD drive.
4. Press and hold the Power button for 5 seconds to turn off the notebook.
5. Press the Power button again to start the notebook.
6. Press Esc key to boot from the CD when HP logo appears. Choose the first boot device as CD ROM and then click enter. The Welcome to Setup screen is displayed.
7. Press ENTER to continue. A Licensing Agreement screen is displayed.
8. Press F8 to accept the agreement and continue. The Setup window is displayed.
9. Press ESC to continue installing a fresh copy of the operating system without repairing.
10. Press ENTER to setup the operating system.
11. Press C to continue using this partition.
12. Select "Format the partition using the NTFS file system (Quick)", and then press ENTER. A caution message stating that formatting this drive will delete all current files, is displayed.
13. Press F to format the drive. The reinstallation process begins and may take several minutes to complete. Your Notebook will restart into Windows after the process is complete.
NOTE: When prompted for the product key, refer to the Microsoft Certificate of Authenticity located on the bottom of your
notebook.
I hope this information helps you. Please reply if I can help you further.
Apr 05, 2010 | Dell Studio 1537 Laptop
Windows XP won't load past the 'user account welcome screen'.
If you boot into safe mode* and have same problem, you might be missing a file called "userinit.exe."
It's located in the /WINDOWS/SYSTEM32 subdirectory. You can copy it from another xp computer
(suggest matching updated pro vs home files). Use your harddrive as a slave on another computer
if necessary.
*safe mode: Restart your computer and start pressing the F8 key on your keyboard during boot up.
Then you gotta ask: how did that file get deleted? It's a popular file to attack by malware authors and
some anti-virus software will delete it as part of an infection cleansing.
May 21, 2009 | Dell Microsoft Windows XP Home Edition
Stuck on the Windows XP Welcome Screen
One of an important file needed to boot up your laptop, or your hardware is loose. Try taking out the ram and putting it back in.
Aug 28, 2007 | Compaq Armada M700 Notebook
Dell Inspiron 1000 Notebook Logo
73 people viewed this question
Alun Cox
