CD Rom/DVD drive
This drive does not react or recognize any discs that are inserted and has disappeared from the list of drivers on my screen.
What can I do to fix this?
  • Anonymous Jul 14, 2008
    teac cd 224e drivers
Check out the Jumper setting of the CD/DVD drive as the Jumper setting is not proper or your H-disk and CD/DVD drive can have the same jumper setting so only can be used at one time .I think you should also update your CD/DVD driver form your system disk.
Posted on Jul 19, 2008
Am having problems with my D drive on my Presario F700. It won't open when "eject" is selected. After manually opening the driver and insert a disc I receive a prompt to insert disc. Any...
Hello dir645,
to have the "DVD ROM" recognized, and 'function' properly!
Do the following:
  • On the "Desktop Screen, {right click} to open the Computer."
  • Select the Properties, in the 'shortcut window.'
  • If you do not have a Computer Icon on the [Desktop]?
  • Click on the "Start Button."
  • In the (right pane), select to open the Computer 'shortcut menu.
  • Choose the "Properties" from the 'list.'
  • Check to see: if there's a DVD ROM Drive letter?
  • ie. (D:) in the "Device with Removable Storage area."
  • If the area is (Blank)?
  • Go to, and select All Programs, after clicking on the Start Button.
  • Scroll to find: the Media Disk Player.
*Note: "You made need to (Setup) the "Player!"
  • [2x] click open the Player, and select to "Setup / Install"
  • Follow all the instructions!
  • Click on the Apply and OK buttons when finished!
  • "Restart the Computer."
Now, go back to: {Start Button -> Control Panel ->
Hardware and Sound -> "Device Manager" -> DVD / CD-ROM drives}
  • Open the [DVD-ROM].
  • "Update the Drivers"
  • Click on the [Driver] button.
  • Select; {Update Driver...}.
  • "Restart the Computer, again!"
!Attention: "Manually "Update Drivers"
  1. Click on the [Update Driver] button.
  2. Select, "Browse for driver software..."
  3. Choose: "Let me pick from a list of device..."
  4. Click on the DVD-ROM Drive.
  5. Click, ["Next"]
  6. "Restart the Computer!"
"If you are satified? Return, and give a "Helpful Rating," Thanks!
Aug 18, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
E-Machines T5048 Desktop - CD drive not working
Go to "My Computer/View System Information/Hardware/Device Manager". Now click on "DVD/CD-Rom Drives" and make sure your CD drive is listed. If it is listed and there is a yellow exclaimation point then the driver is not installed for it and you must install a driver.
Jan 25, 2010 | E-Machines T5048 (7136) PC Desktop
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
DVD/CD drive burns, spins, won't read DVDs or CDs
CD and DVD use different lasers. You appear to have a bad or out of adjustment laser. Replace the drive.
Mar 01, 2017 | Sony Computers & Internet
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Computers & Internet Logo
475 people viewed this question
David Payne
David Payne
