Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Model 665 16874
Dishwasher seems to run a long time, lots of vertical play at center of lower spray arm - 1/4 to 1/2 inch.  Pulled out lower rack and manually spun arm - chatters when spun (rocks up and down while spinning)  Quite a bit of soap left in flip-open dispenser after cycle completes.  Suspect arm is not spinning while running.  1) previous advice was to check the impeller - I removed the spinner arm, round screen cover (4 screws), 1 additional cover with curved side (2 screws) and can get no further looks like the adjoining piece with curved top will remove, but did not want to force.  How to proceed??  (I removed and check the plastic tubing from bottom to top) 2) Motor and pump (?) cycle loudly, but do not hear spinner arm spraying anytime during cycle. - machine just cycles with a sploosh - hummmm sound over and over.   I did find two pieces of heavy transparent plastic tape in the bottom of the cabinet, about 4" long x 1" wide, one of which was partially rolled with thick white substance inside.  Any ideas greatly appreciated.
  • 5 Answers
Removed and disassembled inlet water valve - minature basket filter was clogged with white particulate which felt gritty.  cleaned and reassembled and reinstalled.  Works fine now.  Idiot repairman never mentioned a filter but wanted to replace entire valve at cost of 140 dollars including service call.   sears sux bigtime. And, from my experience with Fixya, so does your service since I never heard a thing since July EXCEPT for an offer to upgrade.  Thanks for nothing.
Posted on Dec 31, 2008
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
My lower rack will not clean bowls or cups and I have to be very careful how I place plates. The serviceman has been out twice and I have run vinegar through multiple times with no improvement. My top...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
We have an older KitchenAid dishwasher (Model e) that cleans dishes on the lower rack just fine but not the ones on top. Anyone have any ideas why or fixes?
Be sure you are not blocking the spray arm for the top rack. If your dishwasher has a telescoping spray arm in the botton center that retracts when the dishwasher is off, be careful about covering it with the dishes
Sep 17, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Dishes on the lower rack are not cleaning properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
xnbbh
Jul 08, 2009 | Indesit 24 in. D63 Free-standing...
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
174 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
