Question about Brother MFC 420CN All-In-One InkJet Printer
Printer Problems The printer keeps telling me that it is low on cayan. I have replaced the cartridge and still says low on cayan I have replaced the cartridge 2 times and the printer says the same thing low on cayan. Can you tell me what I need to do?
  • drunice Jan 14, 2009
    can you tell me where on the back the tape needs to go? thanks!
Mine was doing the same thing. All I did was took black electrical tape over the detection strip in the back so it reads full. Worked like a charm.
Posted on Aug 24, 2008
    New Friend:
  • 182 Answers
Will it still print? Mine has said the same thing many times even after changing ink cartridges. I would just push the stop/exit then It will be ready to go. There should be no problem with printing after that.
Posted on Aug 22, 2008
My printer would not print because the cayan color was low. Once I replace printer ink the printer will only print every other line with smudges in between. What is the likely problem and fixes?
dried or leaky ink near cartridges. Be careful how you clean them. Use mfg recommended directions to avoid static (etc) problems during cleaning.
Oct 28, 2010 | Epson Stylus CX9400 Photo Printer
Photosmart c 7280--light cayan-- how do you clean heads-?
There is an option within your printers software " Head Cleaner "
Run that and it should fix your problem
May 20, 2010 | HP Photosmart C7280 Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
I replaced the cayan ink cartridge, and it says there is no cartridge installed. I bought a second cartridge, and it still says that.
if you install the old empty cartridge and the message does not appear then the cartridge U have bought is not original
Jan 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have replaced the cayan cartridge and the indicator light continues to tell me to replace the cartridge
just press to ignore that.. it will work normally, maybe you gotta cartridge with an old chip.
Aug 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Repaced ink cartridges,
I think it is not recognizing the new cartridges. Try to clean the slots of the cartridges where you place them. Try to clean cartridges bottom.
Than go to windows open the software installation CD provided and recalibrate the printer and there could be one more option to try.
If my advice helps you out rate me.
Thanks
Mar 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Cayan ink cartridge empty but now cartridge installed
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | HP Officejet 9110 All-In-One InkJet...
Printer problems
clean the cartridge head and then reinsert the ink cartridge
May 12, 2008 | Dell 810 All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
79 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
