Question about Dynex 32 in. LCD Flat-Panel HDTV
Playstation 3 I have an hdmi cable for my tv ,when i play the ps3 it works on the hdmi ports,but unable to view the menu on the ps3 and able to watch movies on it.i hook it up to another tv and it works just fine.
  • Anonymous Mar 16, 2014
    When attaching PS3 using HDMI cable there is no signal.
  • 149 Answers
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Posted on Nov 13, 2008
The usb cable on my ps3 is not working will not play on any tv in house it plays with hdmi cables
Playstation 3's will not output display information via usb, it does although have a traditional Playstation style connector port for displaying via component cable/ AV cable. To switch to this display setting without having access to an HDMI television press and hold the power button until the PS3 beeps for a second time. Pressing once it will beep but continue holding until the device beeps again and it will boot into a display "safe mode" and ask you to verify your display settings.
Oct 11, 2014 | Sony Playstation 3 (PS3) Console
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no Red blue and green out
try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
Dec 08, 2012 | Sony PlayStation 3 (320 GB) Console
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Dynex 32 in. LCD Flat-Panel HDTV Logo
539 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
