Question about Maytag Washing Machines
Maytag Neptune front loader, model # MAH5500BWW had a digital error code reading Lr. Will not agitate or spin out.
  • leo011 Jul 12, 2008
    Thanks all, but we went out and purchased another front loader. We had no idea that Maytag had been bought out a couple years ago due to problems with the Neptune causing company collapse and that there was a major law suit going on. We feel much better with the new washer...Samsung Silver..and checked out the warranties on it. Warranty was out on the Maytag. Thanks for all the effort put into solving our problem.
  • 2,326 Answers
The LR can means that the motor has failed or the spinner shaft is seized to the bearing.
Check the wiring harness to the motor it may be loose.
See if you can turn the tub by hand.
If the tub is free and the wiring harness is good preform the motor test.
You will find the test paper in the console.
Posted on Jul 11, 2008
    Sergeant:
    Champion:
  • 417 Answers
I would check you warr in you user man, sometimes they warr the motor on that unit for 10 yrs(certain models) and if its that old a neptune repair kit is in order which includes both motor controller and motor assy
    Genius:
  • 3,422 Answers
Lr means locked rotor.
  • Priya darshan Jul 11, 2008
    The only solution to fix this problem is to get it repaired.There are no home remedies..
    You will need a new motor or motor control board (or both)..
  • 4,472 Answers
The LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit boardat the top of the unit has lost connection to the motor and its controlboard at the bottom (connector loose) or 2) the motor and or controlboard at the bottom have trashed and need to be replaced (P/N12002039).
Hope that helps,
Thanks,
Lee
  • Lee A.
    Lee A. Jul 11, 2008
    You can contact maytag directly at http://www.maytag.com/support/service_pa...
    to get it serviced, as some parts may be under warranty doesn't hurt to find out. The other option is to find a local repair technician.
    If you need any further assistance or information let me know. If you have a moment and can accept and rate this solution accordingly I would greatly appreciate it as I strive to provide fast,accurate, and economical information.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 12, 2008
    I'm glad you got your problem solved. I hope if you have a moment you will accept and rate my solution as I strive to provide fast, accurate, and economical solutions. If you ever need any help in the future don't hesitate to use the ask me feature. My profile page is www.fixya.com/users/leethedeuce
    your very welcome and enjoy the new washer,
    Lee
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag mah5500bww motor/control board failure recall
I had Maytag ship a new motor and motor control board for free and installed it myself in less than an hour. There is a ten year warranty on those parts. You just have to be very firm and insist you have warranty rights by law!
Feb 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washerfront loader quit agitating and spinning out the water. Code on digital read out is Lr can you help me?
LR is a locked rotor. Usually when I've gotten this error code in the past, you have to replace the motor control board and motor as a kit. However, if this kit has to be installed due to a bad motor, the motor carries a 5 year warranty. If it has to be replaced due to a bad board, the board only has a 2 year warranty. The snag is they have to be replaced together as neither of the old parts is made anymore. I can tell you already the motor/ board kit costs about $300 just for the part. However, since these are expensive machines, I would recommend having a maytag authorized tech come out if the unit is less than 5 years old. It would be worth the service call (and armed with this knowledge) to see if the part can't be replaced under warranty. (wouldn't be a bad idea to have your owners manual ready to show that the motor has a 5 year warranty on it as well) Most warranty companies don't know from model to model which parts are under warranty without the owners manual.
Jul 11, 2008 | Maytag Washing Machines
Washing Machines Logo
463 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
