Question about HP Photosmart C6180 All-In-One InkJet Printer
SDHC Card Is there an update for the C6180 that will allow it to read SDHC cards or are we stuck with just plain SD?
  • hillbilly458 Jul 17, 2008
    I know this sucks I just bought a 4GB A-data TurboSD SDHC card for my camera and it works fine in my camera. My HP C6180 does NOT read it though, so I have no way to get the pictures off of the card. I hope there is a fix for this. I am betting I will probably have to buy something else to read it though!
Your camera might have pictbridge and you could just connect that to your printer via usb
or maybe you could get a usb sdhc reader and plug that into the usb of the printer, that might work
Posted on Jul 18, 2008
Hi, my FZ35 cannot read the SDHC card. The SDHC card is ok and readable on the PC... Please help..
Did you try a plain SD card? Some cameras will not read the SDHC cards...plain SD cards are marked as such and will not be more then 2 GB cards...
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Apr 22, 2011 | Cameras
Drivers for detecting 4gb kingston SDHC
SD vs SDHC is a question I get alot. First let me explain your issue. Unless your CARD READER is rated for SDHC chances are its an older model and cant handle the card, even with driver updates. You will need to check the manufacturers website of the device you are using as a reader to see if there are newer drivers. If its a laptop go to the manufacturers page and and be sure and choose Windows XP as your OS. Ok, now to the difference. SD cards are called solid state memory. The internal workings of each hasnt changed much except that the SD card used standard file formatting that was understandable in Windows XP and earlier operating systems. the SDHC (HC stands for High Capacity) uses the same architecture in teh card but changes the way data is stored and read that enables it to hold more data on same size device. (note architecture means design of card type not inside guts) Thus your system and Operating system may not be capable of addressing the new coding and file system changes on teh SDHC cards. Many older cameras (2008 and before) dont recognize SDHC cards either. Good news is they make an SD card (plain) in a 4 gig and you may be able to replace yours at the retailer with teh correct one needed (unless you bought via ebay or other method) Yours is a good question and is often asked, so dont feel bad in anyway. Just look at it this way.. you learned the lesson recently when the pricing between the two is about the same.. I learned the lesson 2 years ago when an SDHC cost about 80$ compared to 19 $ for a normal SD... SMILE!
Jun 28, 2010 | Kingston 4GB Secure Digital High Capacity...
My sd card reader wont do anything when i put in a card what can i do to fix it ?
Replace the card reader, it has died - it happens. Luckily this is a cheap fix.
Apr 11, 2010 | E-Machines eMachines Desktop PC
Got a new memory for my phone it is a nokia 6300 and the memory card is a 4gb sd micro card and it keeps saying card not formatted wot can i do to format it i have tried on the computer but it is still...
Most likely the phone that doesn't read it and the SD card reader can read "SD" cards but not the "SDHC" that a 4G card will be. All SD cards 4G and above are SDHC, and a plain SD card reader will not read this card.
Buy an SDHC reader, and get a smaller (up to 2G) card to use on the older phone that can't read the 4G one. Hope this helps.
Apr 07, 2010 | Nokia 6300 Cell Phone
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it, but it says CHECK SD CARD. I tried another 1GB memory card and it worked. I know that the problem is with my...
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Mar 23, 2010 | Samsung Digimax D53 Digital Camera
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Can't access SDHC card with Rockband 2
Unfortunately, Rock Band 2 came out before the Wii upgrade that allows the use of SDHC cards. Due to the architecture of the Wii which doesn't allow software patches to games, the Rock Band 2 game uses the old drivers that can only read non-SDHC cards.
Unless Harmonix releases a new DVD with the new drivers programmed in, we're out of luck on using SDHC cards with RB2.
May 17, 2009 | Nintendo Rock Band for Wii
My toshiba laptop doesnt read SDHC card
sdhc cards are not backwards compatible with sd card slots. sd cards however are backwards compatible with sdhc card slots. newer card slots and readers are sdhc and sd ready but i'm afraid your only option is to buy a usb sdhc card reader. normally the 52 in 1 readers and ones like that work well and really don't cost a lot on ebay. the only other thing you could try is to put the sdhc card in an sdhc device (such as a camera) and link it up to the laptop that way.
Apr 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
HP Photosmart C6180 All-In-One InkJet Printer Logo
452 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
