Where can I go to find a owner's manual for a BONAIRE WINDOW COOLER UNIT CLIMATE model #6280020
  • jessewickman Aug 13, 2008
    I need a new filter for this same product bonaire window cooler Product# 6280020
koolbreezes
  • 540 Answers
SOURCE: Is it possible to get a new manual for my Vulcan
Check out this website for manuals.
Posted on Dec 22, 2009
SOURCE: I've lost the manual for my Bonaire VSL75
I think you mean "SLV 75" which is the "Integra" model.
I will post one in the manuals section.
Posted on Dec 30, 2009
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
  • 396 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Evaporative coolers are only for dry climate conditions or deserts. They cannot cool as much as central air or air conditioners which have compressors and refrigerant. The mechanics are simple requiring a water float valve, pump, spider (water distribution), aspen wood pads, blower, belt, motor, and switch. The unit must have a water supply to replenish the system due to evaporation. Your system may have a float valve which you need to adjust to shut off when the water pan is full. Floats can be adjusted by loosening the pivot screw and moving the float up and down to adjust the turn off level or by turning the float to extend or retract the length changing the water shutoff position. You do not want the water to be so high it flows out the over flow tube but the water should cover pump base. Plug in the unit and turn the switch to pump if you have that option on your unit. This will engage the pump to force water from the pan up to the spider to saturate the pads with water. After a few minutes turn the switch from pump to low or high cool. New aspen pads will have an distinct smell which will go away after a few days of usage. If you do not have a pump setting turn the switch to low or high cool which will blow warm air at first then start to cool down. You may also have a fan setting which will blow outside air without any additional cooling if the outside air is humid. Occasional maintenance is to make sure the pump is pumping water and the filter basket is clean and all the spiders are working with water flowing freely. You can use a flexible wire to force it in a spider tube to clean it if it is clogged. You may want to change the water after a month to keep the system cleaner from slime and calcium. At the end of the season disconnect the water supply and drain the water pan blowing out the water line if the winter is below freezing. Replace the pads if they have calcium build up or dry. Flush the water pan out and clean the Add some oil to the pillow blocks which are the bearings at each end for the blower. Check the belt and pulley for excessive wear. Cover the unit with canvas to prevent cold air from coming in during the winter. Next summer season all you have to do is uncover the unit and hook up the water supply.
Posted on Jul 27, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have an evaporative cooler:
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Posted on Jan 01, 2011
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
177 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
