Question about Whirlpool Washing Machines
Duet washer has an "F" code, and stopped in mid-cycle. How do I restart? What does the F mean?
  • ezmeals Jul 12, 2008
    It's an F02, which is a drain problem according to the manual. I checked the hose & no kinks, but my washer/dryer combo is stacked and in a closet so it's really hard to disassemble the hose and check if it's clogged. I got the machine to run again by running a "drain and spin" cycle. What else can I do?
  • Toby Norton
    Toby Norton May 11, 2010
    "f" codes are diaganostic codes to tell you where the problem is. What is the number or letters that appear after the "f" code? What is the model of your washer?
  • 246 Answers
I'm so sorry, this didn't update for some reason that you had replied. F-02 is a drain error. Remove the 3-4 1/4" screws from the lower front panel. You will find them all of the way at the bottom of the panel. Once the panel is removed, in the front bottom, center, you will find a white platic container with 2 hoses in the back. This is your pump. There is a "line" running across it. This handle can be rotated counter-clockwise. CAUTION: there is always water left in here. You will need a wet vac or several towels. Once you have completely unscrewed the handle, slide it out. You should find multiple forign objects stuck in this trap, keeping the washer from draining properly. Now re-assemble in reverse. You should be good to go. If this doesn't take care of it, drop me a line back directly (you can click on my user profile) or please send back a information grade.
Posted on Jul 23, 2008
F8 E1 error code
anyone able to tell me what the E1 F8 error code means on a Whirlpool duet steam washer?? it keeps stopping mid cycle...
Jan 05, 2014 | Jenn-Air Ovens
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Whirlpool Duet model (don't know the model number) washing machine front loader is having problems completing a normal load cycle. Please let me know what this "FH" signal means and I will try...
FH means there is no water getting in the washer. Make sure both fill valves are working by selecting first hot then cold if no cold. If one or the other is not working then replace fill valve( or clean if plugged)
Oct 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 02 F
pump is obstructed and needs to be cleaned. Look in this thread for how to clear a duet sport pump trap.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 My washer freezes during mid cycle
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. If the drain pump will not function, the washer will not complete, or restart a cycle. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Sometimes you may also get a "SUD" error in conjunction with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopped
The computer needs to reset. Try unplugging the machine. Plug it back in and then the system should be able to be restarted.
May 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
