I just replaced the fuser in my HP 1200 and after doing so the light is flashing yellow, and I don't know why.
    Sergeant:
    Champion:
  • 417 Answers
Try resetting it
or
you may not of connected it properly
Posted on Jul 11, 2008
Hi there our yeelow light is flashing on HP 1200 Series printer what do you think is the problem?
There can be a number of reasons for this. If you turn the printer off, disconnect the printer cable and then power back on, does the yellow light still come on? Or does it come on after you send a job to it?
If light comes on after send job then it may be the paper pickup roller is dirty and or worn. Take the toner cartridge out and check.
If the light comes on after powering up then you may have a paper jam in the fuser area. That is situated just before where the paper exits. The panels on this printer come off easily. You need to take the rear panel off and shine a torch in the fuser/heat roller area and see if there is any jammed paper.
May 20, 2011 | HP LaserJet 1200 Printer
I getting 50.2 fuser error in hp laserjet printer what i do i don't know can u any one help me
the 50,2 error is a fuser error, and should be serviced by a repair facility. You can try to replace the fuser yourself, but the labor should be pretty cheap compared to the cost of the fuser assembly.
May 06, 2011 | HP LaserJet 5100tn Printer
HP Business Ink jet 1200. Yellow cartridge lite is on. Changed cartridge, but lite is still on,
Ink cartridge lights: Black, Blue, Magenta, Yellow
When light is on - ink is low (below 25%)
When light is flashing - out of ink - printer stops - replace cartridge
To get a printer status / configuration report press the info button (to the left of the on button)
Oct 07, 2010 | HP Inkjet 1200dn Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
HP Laserjet 1200 - continuous blinking yellow light
A flag is a little plastic piece that is hinged and goes in between a sensor and a light source. They use a ton of them in printers. It actually looks like a flag, about 1/8th inch square that can move in between the sensor parts. It's possible that it broke when you took the envelope out. Most likely it's the paper exit sensor in the fuser. They can break easily. If so, then you'll have to get the sensor flag or a whole new sensor. Check with a local repair shop. They should have the sensor and can install it in a jiffy.
Aug 08, 2008 | HP LaserJet 1200 Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
Hp laserjet 1200 printer problem
press the big button for secondary light pattern error code
most likely you have a bad fuser
thanks for rating
Jan 14, 2008 | HP LaserJet 1200 Printer
188 people viewed this question
jasbo
jasbo
