Question about Sony SDM-HS73P 17" LCD Monitor
SDMHS73 monitor is dead, LED on/off switch is also dead
When I press the on/off LED switch on the monitor, the switch showed no response. The monitor is also dead. What can I do to fix this?
  • 983 Answers
Check the power supply cable of the monitor is connected properly or not ...
and also check the cable connecting from monitor to cpu ....
check is there any wire cut s in both the cable ...
if required change the cable ...
try connecting this monitor to other cpu....
if you still persist the same problem then inside the monitor some component might have got burned out ....
the components like capacitors,etc ....
if you are good at opening then just open the monitor and have a check is there any burnt smell or burnt mark on the circuit board ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 12, 2008
Display doesn't work; but not completely dead
There is no user replaceable fuse that will resolve this "no video" condition that you have. You'll need have the unit repaired.
Apr 23, 2014 | ViewSonic VX2255 Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Monitor is totally dead
Through my past experience I mwould remove the solder point at the input power B+ line to primary winding FBT. If the HOT has shorted there will be no power.Straight to the point if you know where the HOT is , you can desolder the middle pin or collector of the HOT transistor. If you desolder the pin which result the power led light turn up. That indicates either FBT or HOT has shorted
Apr 19, 2008 | LG Studioworks 45 14" CRT Monitor
Repair
if the monitor green led is blinking continuosly the follow the steps remove the cable of the monitor which is connected to the CPU and watch the monitor it should show a message ( no input signal or cable disconnected, that means your monitor is OK the problem is with your CPU . try this and let me know
Oct 10, 2007 | Computers & Internet
Help me with ma monitor
Being a 21" CRT monitor (old tube type) it is going to be cheaper to buy a new LCD flat screen than to fix this one. Best bet if you do want to fix this, is to take it to a tv repair shop and let them work on it. You have not given enough information to give a good educated response to what might be causing this issue. Good luck.
Aug 18, 2007 | NEC AccuSync 120 CRT 21" Monitor
Dead
This is an idication that the Hi voltage didnt start up. My experience with these monitors tell me the flyback and horizontal output transistor is bad and probably not worth to repair unless your a tech and know your way around tv circuitry. Its not advisable to go into these sets as there are no user serviceable parts inside. good luck
Jun 10, 2006 | SAMTRON 55V 15" CRT Monitor
Sony SDM-HS73P 17" LCD Monitor Logo
187 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
