Question about Fujitsu M4097D IPC Path-Through Flatbed Scanner
Fujitsu M4099D The bulbs do light.
  • rgk202 Jul 11, 2008
    I switched the front and rear cameras. They are the same part number. I still get the same error.
In case the glass and the camera mirrors are clean, please check the front lamp if the the small slot in the lamp sit in the correct position. You can install the lamp in two positions. One position is OK, the other is wrong. Please check the pictures at the lamp holder with your lamp.
Now an tricky error source:
If the front page camera cabel is broken you get an error message like "front lamp alarm".
The best way to check the camera cable is to test every of the 40 wires with a electric tester. You have to unplug the connector from the camera and on the back side from the junction PCA and then check every wire if there isn't an interrupt.
That's it.
Posted on Jul 15, 2008
  • 25 Answers
Sounds then like a loose camera cable , dirty glass, or white background plate.
Posted on Jul 11, 2008
  • zone48
    zone48 Jul 11, 2008
    There is a fujitsu service program available from Fujitsu called FCPA Twain Scantool. Not sure where you can download it from. If you start it up and connect with the scanner, it sometimes will reset the error in the firmware just by connecting (got me through that problem one time.)
    Try removing the main Rom board in the back and reseating the board. Edge connectors on the board may not be making a good connection.
3 Suggested Answers
zone48
  • 25 Answers
SOURCE: Fujitsu M4099D
The Rom board is the big circuit board that can be removed from the rear of the scanner. I think there are about three screws that secure the plate that surrounds the output jacks. With the screws out, the whole rom board comes out like a sliding tray. The fuses are round and brown in color. BUT warning! Don't mix them up because they are of different values. If you try swapping them around, you will put the wrong value in another slot and it will blow! If your lamps are lit, then the fuses are ok, but try pulling the circuit board tray out and reseating the tray.
If the lamps are lit, then the fuse and lamp inverter is ok. If you swapped the cameras, and the problem still says its the front lamp, make sure that the lamp is turned around to its proper position. The lamps are masked with a clear opening. If that opening is not turned to shine the light at the right position, you could be getting the alarm because of the loss of light.
If the problem shifted to the rear lamp alarm when you switched the cameras, then the camera mirrors are real dirty inside or its just a bad camera.
Posted on Jul 12, 2008
  • 14 Answers
If the front lamp is correctly installed (take a look at the lamp carrier pictures) and all 8 possibilities from zone48 are OK,
then you have to check the cables.
At the front camera right side you see one wide black connector for the CCD data transfer cable and one grey plug for power.
Inside the CCD cable there are 40 coloured wires.
Power plug test:
Use a voltage meter to check the power. In some cases the soldering points at the PCA are broken or the plug pins are burnt.
CCD cable test:
Disconnect the CCD connector at the camera.
Disconnect the CCD connector at the scanner's backside at the junction board.
Screw off the metal cable clamps.
But the two connectors side by side.
Now use a resistor tester and measure from connector contact number 1 to contact number 1 at the other connector if there is a linkage. Then do the same with contacts number 2 and so on.
A lot of work but a must.
By a broken wire you will get no linkage.
In case you found broken wires you need a new cable.
Fujitsu part number: CA04315-F851
Fujitsu part name: CCD Cable
Posted on Jul 16, 2008
FUJITSU SIEMENS CSS LED FLASHING
Orange CSS LED bulb is light what does that mean
Dec 27, 2010 | Fujitsu Siemens Siemens PRIMERGY RX300...
Backend optical error
check on feeder side assembly, there might loos contact on bulb or on bulb controller.
Jun 07, 2010 | Fujitsu fi-4340C Flatbed Scanner
How do you replace the feed roller on a fujitsu 4097 scanner
Hi Ranji,
Thank you for contacting Fixya.
The life span of the Pick roller is about 200,000 sheets or one year. Use Abrasion counter on the operator panel to estimate when the Pick rollers need replacement. The life span may be decreased by as much as half when carbonless sheets are frequently read. To replace Pick Rollers, please follow the steps provided below:
a. Remove Guide AASY. b. To remove the Pick rollers, turn the stopper counterclockwise. c. To remove the Pick roller 1, move the Pick roller 1 toward the left then lift it. d. Right after removing the Pick roller 1, remove the Pick roller 2 with the same way. e. To attach the new Pick rollers, place the Pick roller 1 from right above the groove for the Pick roller 1. Put the shaft of the Pick roller 1 into the groove. Then, slide the Pick roller 1 toward the right side. A Pick roller 1 has the groove in its rubber. Make sure that the bushing is securely fixed to the grooves. f. Attach the Pick roller 2, then slide the Pick roller 2 to the right. Make sure that the bushing is securely fixed to the grooves. g. Turn the stopper clockwise to secure the Pick rollers.
Hope the above information is helpful.
regards,
TechSatya
May 20, 2010 | Fujitsu M4099D/FI-4990C Scanners
Is the back light bulb replaceable in the Fujitsu Lifebook N3010
yes it is and a suitable place to find it is Ebay or search it by part number on google, as NEC will not have the display for it.
Jun 26, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Fujitsu M4099D
What resolution are you at? When scanner manufacturers rate their scanner at a given speed, it is usually :
1. at 200dpi or lower
2. landscape mode
3. plenty of ram on the pc
4. most image enhancements turned off.
If you are running at 300dpi, you scanner will slow down considerably. You can set this is your software, but also check thru the front panel.
You probably won't get 90 ppm in reality, just as you usually won't get the gas mileage posted on the new car sheet ! But you should get at least 70ppm.
Check your operator's manual to access the front panel menu.
Jul 29, 2008 | Office Equipment & Supplies
Fujitsu M4099D
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Fujitsu M4099D
First, you didn't say whether the Front lamps are actually lit. I know that it is difficult to tell on this model unless you cheat the lamp interlock switch and fire up the unit into scan mode.
Front Lamps errors can also be generated by a loose front camera cable. There are no dedicated lamp detectors. The 4099 uses the camera's ccd's to detect if the lamps are burning. It is also possible, but less likely , that the lamp fuse on the main board (slides out from rear) is blown. (Fuse part number CA53004-0227).
From previous experience, there is probably a 95% chance that the issue if coming from a loose front camera cable. Not the kind of thing to get in and check unless you are service savy. I have had several calls that drove me nuts with this issue until I reseated that cable onto the camera.
The Fujitsu service manual list these possibilties :
a. Do the Front side lamps lite up when you attempt to scan?
b. Is the lamps correctly seated?
c. If the lamps don't light up, possible lamp inverter problem or fuse problem.
d. Is the glass surface and white sheet guide clean?
e. Are the connectors at the front camera ccd loose?
f. Is the power supply output normal?
g. Possible front camera failure.
h. Possible connections from camera to the Rom board problem.
Flashing lights?
Hi there
This sounds like a faulty Powersupply.
Before replacing it , try replacing the fuse on the board first.
Apr 14, 2008 | Fujitsu LPF 7200 Multimedia Projector
Fujitsu M4097D IPC Path-Through Flatbed Scanner Logo
273 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
