Question about Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not turn off
I was unsuccessfully attempting to install the Map Update 2009. I am now unable to get the StreetPilot screen to say anything but "loader loading" and it will not turn off.
    Scholar:
  • 52 Answers
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get teh unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Screen froze all of a sudden. Unable to turn it
Went to on-line manual and found out how to remove faceplate and reset as advised in response on FixYa. Thanks.
Nov 09, 2009 | Garmin StreetPilot c340 GPS Receiver
I just purchased the Map update 2009 dvd. I installed everything and the computer said everything was downloaded. I restarted my garlin and it doesnt appear that anything is different then when I...
The only way you can be assured that your map update was successful is to check the version.
1) On your main screen, you'll have a little wrench tool, click on it.
2) On the next screen, go to the "Map" icon.
3) Next screen, click on the "Map Info"
4) Last screen you'll see the maps isntalled and the year.
Best of Luck!
Apr 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Update 2009 maps into c340 how to
Try Here for the updates,
You may have to add Garmin to your trusted web sites !!! Firewall.
In a web browser, tools, internet optoins, security, trusted sites, sites button, add it here.
hope this helps.
Regards.
Dec 06, 2008 | Garmin StreetPilot c340 GPS Receiver
Error when downloading map updates
Try using a different website where you can download the maps for free. These should work. If they don't, you might need a software update from the same web site before getting more maps: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 16, 2008 | Garmin StreetPilot c340 GPS Receiver
Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Jul 04, 2008 | Garmin StreetPilot c340 GPS Receiver
Unlock code
First, I'm rather surprised that you have 2009 map updates... it's still 2008.
Secondly, you may need to call GARMIN to talk to their tech support... they can straighten out this problem if you've already paid for the map update.
1 800 800 1020
You should register your unit on GARMIN's website, it will speed the process.
Jun 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
