Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Green Picture The picture has turned green. Is there any way to fix this?
    Genius:
  • 1,030 Answers
Do you still have video.... is the video green. to me this sounds as if ether the blue or red tube has failed
Posted on Sep 10, 2008
Lg flat screen shows solid green but no picture
Theres a great possibility
that your Power supply unit has problems
Although the fact that somehow turns on
tells us that you may find some bad capacitors and maybe replacing them might fix your problem
Jul 02, 2014 | LG Televison & Video
Some times the picture gets a green and red hue and the menu turns from green to red ,
HI. this is being caused by a faulty convergence chip that is located on the convergence board. simply replacing this chip or replacing the entire board will fix this issue.
May 21, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Picture is tinted green
Contact sony. It needs a new light engine. Sony is fixing due to class action.
Apr 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The picture is green
your picture tube is wearing out . there is a way around it it will work for a while .you need to lower the drive for the green . on the board on the neck of the picture tube there are three adjustments marked red , blue, green on the front of the tv turn down the color all the way down . normally you would have a black in white picture but now you have a green and white find the screw adjustment marked green and carefully turn it down untill the picture is black in white and your fixed . adjust color back up .... dont do this repair unless you are confortable working around high voltages a wrong move inside a tv can kill you , this adjusment must be made with power on so you can see the picture as your going ... so this may not be for you . use your own judgement ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | RCA Televison & Video
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Green Picture
You can, but it's a hard fix. I'm a repairman, and I don't even like to do this one!
Oct 03, 2008 | Toshiba 57H81 57" Rear Projection...
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Feb 12, 2007 | Toshiba 46HM95 46" HDTV
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
