Question about Kenmore Dishwashers
Kenmore ultra wash III dishwasher
All cycles seem to funtion correctly. Water appears to be flowing through the upper and lower arms. The float switch appears to be working. Draining appears to be all right. The dishes come out dirty (not clean). I do not have a manual or know if there is a filter clog'd. I need some assistance.
  • russ9292 Jul 11, 2008
    Hi, thank you for your prompt response.
    Yes, I already removed the upper and lower arms and found they were not stopped up at all. I have, in the bottom of dishwasher a raised piece of plastic about 8 or so inches across, like a dinner plate turned upside down. There are slots all around it and that is where the water comes in and drains out. There does not seem to be anything clogging the water fill or drain. I thought there may be a filter under the darn thing but I guess I will have to pull it out and lay it on its side (that is a real pain if you could see how small and cramped my little kitchen is.
    I do not see where I can remove the lower facing as it looks to be either clamped or screwed on from the inside of the shell.
    I hear it fill and I open the door and see water spouting all over (get wet doing that) and then when I hear it drain I open the door and it is empty, so, it seems it is filling and emptying correctly. Water temp it hot as can be, I have a water softner for the house. It stopped cleaning about 2 months ago but I think it was probably not cleaning gradually (if that makes any sense to you).
    Any more suggestions would be appreciated.
    Never thought of that. I will do that in the morning and let you know tomorrow. I have to go to work - bah humbug. I like the comment that you are a cheapskate.............. LOL Me also.
    Heck if the water is clean where would you go then?
    Come to think about it, If it is dirty what would be the cause? Would that not mean that there is a filter that is not working?
    Questions questions questions..........................
Take off the bottom spray arm. Take off what is below the bottom spray arm.This will bring you close to the pump. There is a little plastic grate. Take the screw out and remove the plastic grate. This should take you right to the intake on the washer pump. Take tweezers or whatever and make sure everything is very clean, that all the intake ports to the pump are clean. It was at this point on our dishwasher that I found debris was plugging the intake holes on the pump. I cleaned it all out, put it back together , and had a brand new dishwasher. Make sure you get right to the bottom intake of the pump, those hole inlets. You do not have to move or tip the dishwasher over. Just do it with the bottom rack out, and the top one out too if it makes it easier. I think I will make this part of my regular dishwasher maintainence every year or two.
Posted on Sep 14, 2009
Well, the water is clean. The only thing I can think of is that the pump is just not doing its job. The only way to know is put a meter or a flow meter on the pump but heck, I can buy a new dishwasher for under $300 so I think I will just give up. Hate to do it but it is not worth the time and effort anymore. I really appreciate your involvement in my problem and I hope I have not over loaded you with my questions. New dishwasher, here I come........ bah humbug. Mine was only 13 years old, they just do not make them like they use to.
Posted on Jul 12, 2008
    Sergeant:
  • 225 Answers
I suggest checking the spray-bars - the upper and lower arms - for debris in the little nozzles. Mine get clogged with jar labels and bits of chipped pottery. You can usually remove the spray-bars by turning the knurled nuts to remove them. Keep a note of the order of any washers or spacers, and you will probably find that the nut on the lower bar has a left-hand thread, so you will need to turn that the opposite way to normal to remove it. Once you get them off you can back flush then under the cold tap to make the junk come out of the big hole in the middle.
The filter is usually a little plastic basket in the bottom of the machine that can be removed by turning it a little anticlockwise and lifting it out for cleaning.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 11, 2008
  • Richard Raynor Jul 11, 2008
    Hmm - seems like you have already done the sensible things! We now need to establish whether the dirt on the dishes is the "original" dirt that wasn't removed by the washing process, or "new" dirt that is being circulated within the machine.
    I'd suggest running the machine on a short cycle with no dishes in it, plenty of proper detergent - I use dishwasher powder from Tesco or Lidl myself because I'm a cheapskate - AND collect the pumped out water in a bucket to see whether that is full of muck or nice and clean.
    Then we'll take it from there if I am still awake.
    Cheers, D.
    "Heck if the water is clean where would you go then?
    Come to think about it, If it is dirty what would be the cause? Would that not mean that there is a filter that is not working?"
    I'm hoping there will be a build up of heavy gritty stuff in you outlet pipe that will come out when you run it into a low level bucket. It might be reducing the flow to the drain so the muck is staying inside the machine, but we'll see when you try it. Cheers.D.
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
No water
Two things to check. First see if anything is holding up the float inside the tub. Located on the bottom right if I remember correctly. I had a fork fall off the rack and do the exact same thing by getting lodged under the float. Second, if there was work done on the plumbing, some debrs may have gotten into the line and clogged things at the inlet valve. You may have water flowing through the inlet line, but maybe clogged at the valve. Need to take that off and check. While you are down there run the dishwasher through a cycle and test voltage at that valve. Also could be the valve or the control board.
Jul 14, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
The dishwasher is not cleaning the dishes at all, so far I have done the following: Checked both sprayer arms and they move freely and do not appear to be clogged (I ran stiff wire thru holes in each The...
Heating element may have burned out. Check water temp during wash--should read between 130 to 140 F.
If not the heating element,you may have to replace pump-motor assembly or wash impeller.
Hope this helps.
Aug 12, 2009 | Kenmore Dishwashers
Kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
May 21, 2009 | Dishwashers
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Mar 14, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Dishwashers Logo
1,674 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
