Question about RCA CDRW121 2-Disc CD Recorder
Hi, my cdrw 121 will not record, it did for a while what is wrong
RCA cdrw 121 recording shuts down at 41 minutes
Depending on the age of the unit the linear sled may have a blockage in the worm gear t that point. Does it play a disc all the way through or does it stop at 41 minutes too. This would be a hint. Make sure you are not recording in a high resolution mode which will cut down on time.
Jan 22, 2013 | RCA CDRW121 2-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Perfect in recording CD's recording of CDRW's (TDK CDRW AUDIO nor MAXELL CDRW XL II music) not possible. how to fix?
If the CD recorder records data discs, and is not a CDRW recorder it will not record on them, also there would be no reason to record a audio CD if the unit records data discs
Dec 11, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
OS is Windows XP Professional CD drive will not reconize a DVD+R for recording data. The drive is a HL-D-ST CDRW/DVD GCC4244.
A CDRW/DVD is a CD-burner and DVD-ROM combined unit. It is not meant to record DVDs only CDs.
It will not recognise a blank DVD as it is unable to read any file system.
Jun 01, 2009 | Dell Computers & Internet
Nee RCA CDRW 140 User's Manual
got one for cdrw 120 i think they are amost the same. ??? Can Send Copy
[email protected]
Dec 29, 2008 | RCA CDRW120 2-Disc CD Recorder
My Samsung CDRW/DVD SM352F plays commercial DVDs but will not recognise an inserted DVD/RW for recording picture files and shows properties as O bytes used space and O bytes free space. What is wrong?
the drive you are using is called a combo drive
CDRW- means CD WRITER
DVD- means DVD READER
DVD WRITER is not included in this combo...
only cd could be read and also written
but is case of DVD , it could only be read..
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
Cdr 121 rca
Some CD burners will only work with specific CD's.
CD+R (most common format)
CD-R (other format)
CDRW (Re-writeable)
Check manual for correct working type of disk that works with your machine.
Jan 27, 2008 | RCA (CDRW121) Burner
CD's used to record on The RCA CDRW 120 RECORDER that is compatible with my computer for the Automation System.
You are finalizing the CD after recording? After finalization they should play in all but very old CD players.
Jan 12, 2008 | RCA CDRW120 2-Disc CD Recorder
RCA CDRW121 2-Disc CD Recorder Logo
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
