Question about Chatterbox Radio Communications
Installation we have a chatterbox hjc50 tandem pro intercom and need to know how to install it on a closed face helmet
  • haye2433 Jul 11, 2008
    how do you install a chatterbox hjc 50 tandem pro intercom on a closed face motorcycle helmet?
  • 120 Answers
SOURCE: Chatterbox FRS-Pro can not communicate each other
check to see if they are on the same channel, and if both have good batteries, batteries can be good for receive but not have enough power left in them to transmit.
Posted on Mar 07, 2009
  • 10 Answers
SOURCE: programing helmet chatterbox to cell
Push and hold the GMRS-X1 intercom button and turn the unit on, continue holding the intercom button down until the display changes to "BT" and the bluetooth indicator flashes. - then seek device's on your cell as usual, pairing code is 0000
Posted on Aug 16, 2009
  • 11800 Answers
SOURCE: Had two units for over
Each unit is composed of 3 elements: an emitter, a receiver, and a simple processor. In the case of your wife's unit the emitter has failed. That is unfixable, the units are set in sealed cases and not designed to be opened or repaired.
Sorry, they are dead, time for new ones.
Posted on Sep 03, 2011
  • 130 Answers
SOURCE: my chatterbox xbi2h plus helmet headset will not flash blue so as to pair it with my iphone
Check battery for charge
Posted on Apr 30, 2014
Testimonial: "Thanks. so simple yet so frustrating thankyou very much"
joeaxe
  • 263 Answers
SOURCE: Veetop crash helmet intercom, I need a instruction manual,
Posted on Mar 26, 2017
Why When I push PTT on my chatterbox the whole thing powers off
When you hit the PTT the radio draw more power and either the battery can't provide the current or you have a bad connection. Try changing the battery
Jul 25, 2014 | Chatterbox GMRSX1 Bluetooth Communication...
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
Jul 03, 2014 | Cardo Scala Rider Teamset Pro
Tandem Breakers
The use of 2 15amp breakers first had meaning. If you can relocate with one tandem 15 amp it means that there will be no protection cuase the tandem tripping point does not count.
Feb 12, 2014 | Eaton Corporation BR4040B200 Main Breaker...
Cant get my box lacrosse facemask to fit my helmet
Is it possible that your helmet morphed a bit? I once left my sons helmet in the sun for not 5 hours and by the time I remembered it, the helmet was a completely different shape. If this is not the case, I suggest that you go to your local sporting good store and have someone take a look at it since it's pretty hard to know exactly what issue you are having without looking at it.
Jan 30, 2013 | Under Armour Pro Box Lacrosse Cage Face...
Programing helmet chatterbox to cell
Jul 07, 2009 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
If i want to talk to my passenger what do i do?
you will need the headset extension cord. push and hold the "int" button till a beep is heard then either ptt or vox
May 14, 2008 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
Radio Communications Logo
48 people viewed this question
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Shaun Baxter
Shaun Baxter
Level 1 Expert
John L radiodude365
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
