Question about Canon Office Equipment & Supplies
I have a Canon colour image runner C3308i and I am trying to print to it from my computer, it's not working. I get error NG #701 does anyone know how I can fix this??
5 Suggested Answers
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
  • 135 Answers
SOURCE: Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Posted on Apr 19, 2009
  • 13 Answers
SOURCE: What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Regards Mug71.
Posted on Sep 14, 2009
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Cannot print to canon c2880 image runner from vista 64 laptop
Sounds like you don't have the proper Vista x64 bit driver installed. It's different from both XP and standard Vista Drivers?
Get it here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=14357
Jul 23, 2009 | Canon imageRUNNER 5020i Copier
How to align an image runner C3200
The colour alignment is carried out automatically. Run auto gamma adjust. If this does not resolve anything, some part is at fault. Typical faulty item would be slipping transfer belt.
Mar 31, 2009 | Canon imageRUNNER C3220 Color Copier
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Aug 15, 2008 | Canon imageRUNNER C3200 Copier
Won't Print
Did anyone change some thing in the computer?? Or added new software?? Also, did someone change the user setting on the copier, Maybe to just a copier or just a fax??? Do some huntting and get back to us
Jun 25, 2008 | Canon ImageRUNNER 1670F Copier
277 people viewed this question
old marine
old marine
