I need to replace faulty fan oven element on my Baumatic model no B144SS. I have ordered a compatible element from Random Spares so hope this is acceptable.
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories.
I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe.
In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link:
http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B
Hope that helps! ;)
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element.
if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
replace element
