Question about HP Computers & Internet
My windows explorer stop responding and was closed
    Champion:
  • 217 Answers
If you hit ctrl-alt-delete, task manager should open. you can click on File, then New task. type in explorer.exe and hit OK. It will restart it for you.
Posted on Jul 11, 2008
Tip
How to avoid losing your work in case a program stops responding
Sometimes, while doing some specific work on your PC or browsing the internet, the program you're using suddenly stops responding without any apparent reason. If you hadn't been saving your work regularly, you'll most likely lose it when Windows prompts you to close the program.
There's however a solution that could help you avoid such frustration. Here are the steps to follow in case a program stops responding :
1. Once you encounter such a problem, don't close the program you're using.
2. Open the Task Manager by pressing Ctrl + Alt + Delete.
3. In the "Processes" tab, find "explorer.exe", choose it and click "End Process" on the bottom right.
4. Click "Yes" (Everything you see in the background will disappear but don't panic, it will come back).
5. Click "File" on the top left.
4. Choose "New Task (Run...)"
5. Write "explorer.exe" in the box.
And everything comes back! You can now resume your work...
on Sep 28, 2010 | Computers & Internet
Hang up internet explorer not responding
If you use Internet Explorer you may experience issues where the browser freezes, hangs up and stops responding.
Although many things can cause the browser to stop responding, if the problem persists there are a few troubleshooting techniques that you can use to fix the problem.
Troubleshooting Internet Explorer may require you to perform a few steps or several, depending on the cause of the problem.
Click "Start," choose "All Programs" and click on the "Windows Update" option.
A new window will appear.
Click the "Check for updates" link on the left side of the window.
Windows will connect to the internet and search for updates for your system.
Click the "Install updates" button on the right side of the window.
Windows will automatically download and install any updates it finds.
Restart your computer, if prompted.
Delete Temporary Internet Files
Click "Start" and select "Control Panel."
Click the "Network and Internet" selection then click on "Internet Options."
The Internet Properties dialog box will appear.
Click the "Delete" button beneath the "Browsing history" section.
Place a check-mark next to "Temporary Internet files" and click "Delete."
Allow the computer to delete the temporary internet files then close the Internet Properties dialog box.
Remove Problematic Add Ons
Click "Start" and enter "Internet Explorer" into the Windows search bar.
Click on "Internet Explorer (No Add-ons)" when it appears in the list.
Internet Explorer will launch with no add-ons running.
Click "Tools" on the right side of the browser and select "Manage Add ons."
A pop up window will appear.
Click on "Toolbars and Extensions" beneath the "Add on Types" section on the left side of the window.
A list of add ons will appear on the right side of the window.
Scroll through the list of installed add-ons and locate third party add ons that you've recently installed.
Note that you can look at the "File date" for a date of when you installed the add on.
Look for add ons that you installed at approximately the same time you began experiencing issues with Internet Explorer not responding.
Click on any suspected problematic add-ons and click the "Disable" button at the bottom of the window. Close "Internet Explorer (No Add ons)" and restart the browser normally.
Verify that disabling the add-on fixes the problem.
If not, repeat this section and disable another recently installed add on until you fix the problem.
Hope this helps.
Nov 19, 2012 | Computers & Internet
How do i close internet explorer and windows messenger?
Hello there and thank you for choosing fixya
Well there are a couple of different ways of doing this
First if the screens are locked and wont respond by the normal way then simply do a end task and press end on the windows explorer and windows messenger when you see them
Next iy you have them on the taskbar simply right click on them and choose close window and wait for it to respond which may take about 30 seconds or less
and the final way is to restart the computer ok
Hope this is very helpful for you
Best regards Mike
Mar 11, 2011 | Microsoft Internet Explorer 8
The ie is not responding
This may be caused by a Third party addon. Please reset the IE settings to disable add-ons:
1. Close any IE or Windows Explorer windows that are currently open.
2. Open a new IE window.
3. Click the Tools button, and then click Internet Options.
4. Click the Advanced tab, and then click Reset.
5. In the Reset Internet Explorer Settings dialog box, click Reset.
6. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
7. Close IE. (The changes will take effect the next time you open IE.)
Jun 27, 2010 | Microsoft Windows Vista Home Premium with...
Micro soft told me to get a fix for the tool bar. My internet connection just stopped responding until I closed out of the window i was in.
Goto TOOLS then go down to INTERNET OPTIONS then click on the ADVANCED TAB and right above ok and cancel there is a button to RESET internet explorer to defaults click on that and after that close internet explorer and reopen it and it should work.
Toolbars like google and yahoo can cause problems.
Jun 23, 2010 | Computers & Internet
Whenever I start scan, it stops responding after 5
your window can come up again:
1 open taksmanager
2 click on new task button
3 type explorer.exe
your window will come again.
in regards to antivirus:
i think u have to reinstall freshly, the present copy has become corrupted.
Feb 10, 2010 | Symantec AntiVirus Scan Engine
Internet explorer stops working
Microsoft has suggested people uninstall SP1 for Vista for the time being until they resolve some problems.
You should find this as an uninstallable program in Control Panel Add Remove, scroll down until you see the entry.
If you don't contact me with the comment box below and we'll try the alternative method.
Thanks for responding to my questions. You can't imagine how many people just don't and give up before we've had a chance to work with you to solve and fix your problem.
Regards,
Worldvet
Jul 07, 2008 | Compaq Presario 700 470024-192 Notebook
Windows explorer stops responding
you got a virus, superantispyware is a free one that will remove most of them if you dont have antivirus then download free avast antivirus that one will help you remove all of that.
Jun 23, 2008 | Compaq Presario Laptop
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
