New lexmark X5495 is identified by PC via USB port but wont print, giving message "can't communicate with printer". any ideas?
  • shanjohn Jul 12, 2008
    Thanks. I already tried that.
  • schrockii Nov 21, 2008
    I have tried a different cable. manually removed Lexmark from the registry, and all lexmark files I could Identify, tried to reinstall. tried it on another computer and it worked fine on another computer.
  • 43 Answers
Try to connect it with different usb cable
Posted on Jul 11, 2008
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
My lexmark 5300 all in one gives me a "web gateway encountered a problem..." message and the printer's functions will not work.
Does your printer print when you try to make a copy using the Copy button on the printer operator panel? If yes, then it could be a printer driver problem. Try to re-install the printer driver on your computer. You can download the Lexmark X5495 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. After the installation is successful, try to print again.
Jun 14, 2011 | Lexmark X5495 Printer
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
My Lexmark x5495 will not print. I get the message enable bidirectional communication. I am running XP operating system. What is the solution?
Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/cgn74X. Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 04, 2010 | Lexmark X5495 All-in-One &USB...
I just put new ink Cartridges but still wont print
Most of the time the "problem communicating with the printer" message pops up on Lexmark X1185 series when the driver gets corrupted. The best fix for this issue would be to uninstall the software first. Try connecting the USB to a different USB port (Please avoid using USB hubs, if any) and then reinstall the software. This should normally fix the printer communication issues!
Good Luck
Dec 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
1st -make sure that the USB cable is connected on the correct port of your printer - you might be plugging it on the ports of the telephone - you got 3 ports there - 2 for the telephone ports and 1 for the USB
2nd- check your service if print spooler and lx devices are started (lexbce or lxdcu) - if not.... start it
>start >run>type services.msc > enter
3rd- if still no go - uninstall your driver and download windows vista x64 printer driver on their website
Jan 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
43 people viewed this question
jasbo
jasbo
