Question about Sewing Machines
Necchi esperia can you tell me the steps to thread this older sewing machine? I couldn't find the exact product name in your listing. Old machine need help threading
  • lastone64 Oct 05, 2008
    i need help threading a model 1556
  • 323 Answers
SOURCE: I need to know how
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Posted on Jan 03, 2009
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
  • 1116 Answers
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
Posted on Mar 06, 2010
SOURCE: I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Posted on Aug 01, 2010
Can a bobbin case be purchased for a Necchi sewing machine Nova esperia Not sure what the model is. There is a number 29-0016972 on the frame.
If you have the old bobbin case, take it and the make/model to the local sewing repair shop. They will either have one in stock or can order one for you.
Apr 14, 2017 | Necchi Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
Do you have a demonstration or diagram of how to thread and install bobbin for necchi 537L sewing machine?
Try this web site:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
May not have your exact machine but one may be similar enough so you can thread your machine properly.
Nov 25, 2015 | Necchi Sewing Machines
I just inherited this machine. Is there a diagram showing how to thread it?
Here is the most comprehensive list of Necchi machine.
I don't fine a 750 but one of these machines may be close.
Machines name begins with Necchi at Relics Page 1
Mar 20, 2015 | Sewing Machines
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
Please tell me exactly how to thread the bobbin on a 3620. I have followed the instructions, but I don't have a picture showing the bobbin when finished. I start with the bobbin thread coming from left...
I also own 2 necchi sewing machines, I used to have a 3620 myself,,
in my operation manual it has a picture of threading the bobbin case,, if you would like a picture send me a comment with your email address
Nov 17, 2010 | Necchi 3620 Quilter Mechanical Sewing...
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
Oct 31, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
117 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
