Question about Lexmark Wheelwriter 1500 Typewriter
Typing Thanks for your help! I have a little problem. My typewriter is Wheelwriter 1500. I cann't typ whole line, because the typ hard just at the middle of the typewriter, I just typ right side. So, I want to fix back. Thanks a lot!!
  • Lexmark Master
  • 3,594 Answers
Your description was a little hard to understand, does the carrier not go left og center or does it just start printing at the center?
If it goes left but dosen't start printing till the center check to see if the platen (roller) is fully seated in the side frames.
If it stopps in the center reset the L. margin.
DickyO
Posted on Jul 12, 2008
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Type is faded and old looking even with new ribbon.
Put in a multi part form, if the carbons print well then try a fresh ribbon,. not one that has been sitting around for a long time. If it is bad check for debris around the print hammer, If its clean either the print solenoid is gummy or the solenoid cap is broken.
DickyO
Jan 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
Wheelwriter 10 Series II
Try a little light oil on the printer shaft. WD40 works well.
DickyO
May 13, 2008 | Lexmark Wheelwriter 10 Series II...
Squeaking
There are many things that will cause squeeking. First does it make noise when you tab or return if so open the cover and see if it goes away if so the red indicator may be rubbing on the margin scale, bend it back a bit. If it only squeeks when typing try a little WD40 on the motor that drives the print wheel the back bearing is a little hard to grt at.
Not correcting. Be sure you have a correctable ribbon on it(yellow og orange knob)
Hope this helps
DickyO
Feb 26, 2008 | Lexmark Wheelwriter 1500 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
