Question about Canon PowerShot A540 Digital Camera
I'm able to view previous photos in my camera but, when i try to take photograph it says change batteries. i've put new batteries into it.. Plz help
  • Canon Master
  • 4,738 Answers
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please see this link for more info.
Posted on Jan 08, 2011
SOURCE:
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
Samsung PL50 with Samsung 2GB memory card says 'memory full' even though I've cleared down the memory via my laptop.
Have you actually formatted the card in the camera ? Just copying the photos does not remove them from the card
Jul 15, 2017 | Samsung SL202 / PL50 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
I have a DMC-TZ2 that I bought a few years back. Yesterday I tried to take a photo with it, but no image came up in the view finder - it was completely black. I can still change settings and view photos...
Yes this is the same problem as mine. Have been told it is definitely a lens problem and may end up costing more than the camera. Have been advised to take it to a Panasonic Repairer which I haven't got around to yet as I am using another camera. I would still like to have it fixed as it is a great camera and a present from my Dad. Donna
Sep 12, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Write error / Read error
hi
i think the memory card that you are holding has gone bad
just to confirm this try connecting the card using a card reader to the PC and while at it, change the output of the camera to the other card (CF/XD) and try to check if this workssss
happy photographing, enjoy
cheers
Pls rate if this was any help
Jul 13, 2009 | Fuji FinePix S1000FD Digital Camera
Canon Power Shot SX10 IS - I've had camera for about 4 months. As of a week ago, I can only use small view finder for taking photos; the 2.5 screen for viewing does not work now. Able to view photos...
You can reset the camera to factory settings. If after that, you still have the same problem, make valid the Canon warranty since it's 4 months old.
Regards,
Jun 30, 2009 | Canon Rebel XT / EOS 350D Digital Camera
D40X: can't access menu with card in camera
Try "Custom Settings Menu" -> "06 No memory card?".
Does it have any influence?
Tom
Aug 16, 2008 | Nikon D40x Digital Camera
Blurry/strippy photos
Nothing seems to help. My camera just started doing this. I'm taking it back...
Aug 13, 2007 | Nikon COOLPIX P4 Digital Camera
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Can I view photos on my iPod photo/"Color"? nano?
Depending on the model, to view photos on your iPod photo/"Color", you either need to import photographs using Apple's iPod Camera Connector, or transfer images from your computer through iTunes 4.7 or higher to the iPod. For the current iPod U2 Special Edition "Color", iPod "Color" (20.0 GB), the version of the iPod photo (60 GB) introduced on February 23, 2005 and renamed iPod "Color" (60 GB) on June 28, 2005, as well as the discontinued iPod photo (30 GB), the simplest way to transfer photos from many digital cameras to your iPod is to purchase and use Apple's iPod Camera Connector (US$29). This device simply allows you to directly connect a digital camera to the camera connector and in turn connect the camera connector to the iPod "dock" port. Photos imported using the iPod Camera Connector are immediately viewable, with the exception of RAW format images and video clips. However, photos imported using the iPod Camera Connector cannot be immediately viewed as a slideshow with transitions. On versions of the iPod photo (40 GB, 60 GB) released prior to February 23, 2005, photos transferred directly from a digital camera using an iPod-compatible media reader are not immediately viewable, but photos transferred through iTunes 4.7 or higher, which converts photos into a "thumbnail" format, can be viewed on the iPod photo itself or displayed using the iPod photo connected to a TV or projector. The iPod nano, introduced September 7, 2005, can display photographs on the internal display "loaded" from a computer, but as it lacks video out, it cannot display photographs on a television or projector. The iPod nano also does not support the iPod Camera Connector or third-party solutions, so photos cannot be transferred from a camera. For information regarding the iPod nano and accessory compatibility, please refer to Apple Support
Sep 29, 2005 | Apple iPod nano
Canon PowerShot A540 Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
