I have an older maytag commercial washer . The motor hums when it is ready to spin after the rince cycle. If I lift the lid immediatly and wait about 2 minutes, then close the lid the machine starts and completes the cycle. This only happens every few loads.The rest of the time everything works as normal.
    New Friend:
  • 51 Answers
The lid activates a micro switch. If it is not pushed down properly it waont spin. This switch is meant to inhibit the spinning process for safety reasons.
Posted on Jan 03, 2018
catriver
  • 878 Answers
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Posted on Oct 20, 2006
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 57 Answers
SOURCE: Humming noise during spin cycle
call a repair man and have him change the drive block. it is about 30 for the part
Posted on Feb 16, 2008
Lumpy816
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
dh1200s
  • 335 Answers
SOURCE: Four year old maytag neptun fav6800
Hello Ron, I’m an owner/DIY’er I will try to help. I’ll go out on a limb here and say that you are experiencing a classic clutch malfunction with this machine but I could be wrong. Let’s not shoot from the hip with the door switch response and troubleshoot the problem. If you can take the time to read through my post of Jan 29
http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
and try the first two troubleshooting steps to determine if the “dc” errors are caused by a clutch malfunction causing the tumblers to rotate in the wash basket while in spin cycle . If your handy and can tolerate some down time to troubleshoot/repair the issue you might be able to extend the service life of your $1K machine with low out of pocket $. See the links in the above post of responses by a couple of forum members who had these errors and were able to perform the maintenance fix I performed. Our issue was a clutch maintenance issue not a hard failure. I would have replaced the clutch if the spring was broken or bearings rusted out. The 2nd forum member comments are buried down in several comments. Please take a look at the Service Manual
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
and see if you feel OK to pull the clutch out of the machine page 47 has the details. It’s a tight work area but can be removed and replaced without pulling the tub out of the machine. I did jack up the tub a bit to get a 3/8” socket wrench in there to remove the clutch pulley bolt and drop the clutch out of the machine.
I repaired my machine with several shots of WD-40 to clean up and re-lube clutch roller bearings, no hard failure just maintenance of a poor design. My machine failed at the 3.5yr mark. Good luck, Rich.
Posted on Feb 23, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
My maytag washer wont spin after rince cycle makes clicking sound
Ok, if its coming from the bottom, this will confirm an electric motor failure. this motor has two speeds. the second speed is what you need for the spin cycle. If the timer initiates this spin cycle and the motor is faulty, it will only click and stop. it could be because of a failed motor windings within the motor case or just old age.
replacing the drive motor will fix this issue with the spin. i will post a link below for your motor assembly. you can order it on this site if you choose to.
Click here.
Please rate and god bless:)
May 05, 2009 | Maytag Washing Machines
Washer will not drain
By lifting the lid you are performing the job of the timer. In your unit you have a neutral drain transmission and the timer is programmed to end the washing cycle by stopping the motor. When it starts back up, it reverses and the transmission is in the neutral state. The water drains and after about 3-4 minutes, the timer is suppose to disconnect power to the motor thus stopping the transmission inducing the transmission to shift into spin. When it starts back up, it spins. So when you lift the lid, you pause the motor and the transmission shifts. Close it and it spins. Replace the timer and you will be fine. If I can help further.....
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Washing Machines
Washer won't spin dry
Safety switch is not opening. When you leave lid up you are negating the safety switch which is activated by the door. Easy fix.
Mar 31, 2017 | Whirlpool LSQ8243H
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
