Question about Motorola Cell Phones
I need to know shortcuts to texting.An example is when I start to type a word the word I want is highlighted before I am done. How do I insert their word?? Anyother shortcuts appreciated too.
Yes thanks I did figure it out for free and if you would like my answer I would like to offer you my Premium Assistance Plan I need to know shortcuts - 36_12_6.gif
Posted on Jul 12, 2008
Tip
How to recover shortcut files from a flash drive or memory card
Ever experienced plugging your flash drive or memory card and found that your files have been made shortcut and when you tried opening the file nothing happens? Here is one solution that can recover your files.
1. when you plug your flash drive and see the shortcut files, do not delete the files as it will take longer time to recover it. Take note of the drive that reads your flash drive. (see the highlighted text)
3. open the command prompt window which looks like this
4. then on the c prompt type: chkdsk (name of the drive of the flash drive {e.g. g or d}) the command prompt will look like this:ninyarica_3.jpg
5. then you will see the following words on the command promptninyarica_4.jpg
6. wait until it is completed
7. then type exit, to close the command prompt window
8. check your flash drive now, the shortcut files have been recovered.
9. now, you need to clean your flash drive to remove the virus. You have to have a good antivirus to do this.
10. you can now delete the shortcut files if it not removed automatically by the antivirus you used to clean the flash drive.
these steps helped recover my files from my flash drive. Hope it will help you too.
if the steps above did not work or did not recover your shortcut files, you can try this alternative
11. on the command prompt, type: attrib -h -r -s /s /d g:\*.* your command prompt window will look like this: ninyarica_6.jpg
12. wait until it is finished or until you see: ninyarica_7.jpg
13. then exit the command prompt window then check the files on your flash drive, not only will it recover the shortcut files but it will also recover some deleted folders
on Apr 24, 2011 | Computers & Internet
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Aug 25, 2013 | Computers & Internet
I need to copy text with this built in mouse on my Toshiba laptop...cannot figure it out.
Hi there! To copy text follow these steps, 1) Put the mouse cursor at the beginning of the text you want to highlight. Click the left mouse button and then drag the cursor to the end of the text that you want to copy. The text should now be highlighted blue. 2) Right click on the highlighted blue text 3) Left click on the "copy" option in the menu that just opened.
If you cannot get the right click menu to work, there is a keyboard shortcut for "copy" - CTRL-C After the text is highlighted, press those two keys at the same time to copy.
To paste, right click where you want the text to go, then select "paste" - keyboard shortcut is CRTL-V
Alex
May 30, 2011 | Toshiba Satellite Pro L300 Notebook
Tip
Computer mouse tips
Using the mouse in combination with the keys on your keyboard can give you several different advantages and help improve your overall productivity on the computer. Below are just a few examples.
Almost all text editors
Many text editors or programs that allow you to edit text support the ability to quickly highlight all or portions of text by using the Shift key and the mouse. For example, move the cursor to the beginning of the text you wish to highlight, hold down the shift key, and click at the end of the text you wish to highlight. If supported and done properly this will highlight all text in-between the points you clicked.
Microsoft Word
In Microsoft Word holding down the ALT key on your keyboard while clicking and dragging your mouse and you will be able to drag a box and highlight only portions of text and not the whole line.
Windows Explorer and many other file
Microsoft Windows Explorer and other file managing programs allow users to select multiple files by holding down the CTRL key and clicking each file or folder they wish to select or hold down the shift key and selecting multiple files at once.
Microsoft Internet Explorer, Mozilla Firefox, and other browsers
Users who visit a website with tables and wish to only select one row of that table can hold down the CTRL key and click and drag on the text in the row they wish to copy.
Mozilla Firefox users
Mozilla Firefox users can also hold down the CTRL key and individually click on each cell they wish to copy.
on Sep 03, 2010 | Computers & Internet
Tip
Top 10 keyboard shortcuts everyone should know
Using keyboard shortcuts can often cut the time it takes to do something on a computer in half. Below are our top 10 keyboard shortcuts we recommend everyone memorize and use.
Ctrl + C or Ctrl + Insert
Copy the highlighted text or selected item.
Ctrl + V or Shift + Insert
Paste the text or object that's in the clipboard.
Ctrl + Z and Ctrl + Y
Undo any change. For example, if you cut text, pressing this will undo it. This can also often be pressed multiple times to undo multiple changes. Pressing Ctrl + Y would re-do the undo.
Ctrl + F
Open the Find in any program. This includes your Internet browser to find text on the current page.
Alt + Tab or Alt + Esc
Quickly switch between open programs.
F1
Open help for the program you're in.
Ctrl + P
Print what's currently being viewed in programs such as Microsoft Word or your Internet browser.
Ctrl + Left arrow / Right arrow
Move the cursor one word at a time instead of one character at a time. If you wanted to highlight one word at a time you can hold down Ctrl + Alt and then press the left or right arrow key to move one word at a time in that direction while highlighting each word.
Ctrl + Home / End
Move the cursor to the beginning or end of a document.
Page Up / Space bar and Page Down
Pressing either the page up or page down key will move that page one page at a time in that direction. When browsing the Internet pressing the space bar will also move the page down one page at a time.
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
Tip
Microsoft Outlook tips
Create underlines without any text
This tip works with the majority of Microsoft Office applications. Easily create an underlined space by pressing CTRL + U to start the underline, then press SHIFT + Space for each underlined space you wish to create. An example of how this could be used is for printable forms, for example: Name: .
Print only sections of a document
Save on your printer ink by selectively printing in Windows programs such as Microsoft Word, Internet Explorer, WordPad, Outlook, etc. To do this highlight portions of text you wish to print and click print. In the printer dialog window under Page Range choose the option Selection. It is important to realize that not all programs or printer drivers support this feature.
Help control your incoming e-mail with the rules wizard
Use Microsoft Outlook Rules Wizard to help screen your e-mail and delete mail that you are not interested in.
Additional information about the Rules Wizard as well as information about preventing SPAM can be found on document CH000477.
Shortcut to quickly find users in your address book
Quickly locate a user in your address book or a company address book by typing portions of the name or alias and pressing CTRL + K. For example, if you wished to send a mail to John Doe, typing "jo do" and then pressing CTRL + K will automatically complete the name John Doe, unless other names exist with "jo" and "do." This is very helpful with a large corporations address book, especially when you don't know how to spell someone's name.
Quickly undo mistakes
Quickly undo mistakes in the majority of most PC Windows program by pressing CTRL + Z.
Helpful outlook shortcuts
While in Microsoft Outlook press CTRL + SHIFT + I to quickly go to the Inbox.
on Dec 27, 2009 | Computers & Internet
Tip
Microsoft Excel tips
Auto sum shortcut key
Quickly create a Microsoft Excel formula to get the sum of all cells by highlighting the cells you wish to know the value of and pressing ALT and = .
Create hyper links in Excel
Quickly create hyper links in your Microsoft Word, Excel, or Front Page document by highlighting text and pressing "CTRL + K".
Close all open files at once
Close all open Microsoft Word and/or Excel files by holding down the shift key and clicking "File" and then "Close All".
Quickly open recently opened files
Quickly open the recent files by first pressing "ALT + F" to open the file Menu and press 1, 2, 3, or 4.
Repeat recent action
Using the F4 key in Microsoft Office 2000 and above allows the user to repeat the last used action. For example, if you have changed the font of a selected text and wish to change another portion of text to the same font, pressing F4 will do this for you automatically.
Quickly undo
Quickly above cell contents
In Microsoft Excel press CTRL + SHIFT + " to copy the above cells contents.
Using the Microsoft Excel Auto filter
Organize cells quickly by using Microsoft Auto filter. Columns that contains long listing of data can be easily sorted by using the Auto filter option, to use this option select the top rows of the columns you want to be used and select Data / Filter and Auto Filter. Once successfully completed you can use drop down arrows to filter the data automatically.
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
Speedup your work using shortcut in windows
You can use these shortcuts when using windows.It will speedup your work. Please try them.
• CTRL+C (Copy)
• CTRL+X (Cut)
• CTRL+V (Paste)
• CTRL+Z (Undo)
• DELETE (Delete)
• SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
I know they all above are general, but you can enjoy the followings:
• CTRL while dragging an item (Copy the selected item)
• CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
• F2 key (Rename the selected item)
• CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
• CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
• CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
• CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
• CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
• SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
• CTRL+A (Select all)
• F3 key (Search for a file or a folder)
• ALT+ENTER (View the properties for the selected item)
• ALT+F4 (Close the active item, or quit the active program)
• ALT+ENTER (Display the properties of the selected object)
• ALT+SPACEBAR (Open the shortcut menu for the active window)
• CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
• ALT+TAB (Switch between the open items)
• ALT+ESC (Cycle through items in the order that they had been opened)
• F6 key (Cycle through the screen elements in a window or on the desktop)
• F4 key (Display the Address bar list in My Computer or Windows Explorer)
• SHIFT+F10 (Display the shortcut menu for the selected item)
• ALT+SPACEBAR (Display the System menu for the active window)
• CTRL+ESC (Display the Start menu)
• ALT+Underlined letter in a menu name (Display the corresponding menu)
• Underlined letter in a command name on an open menu (Perform the corresponding command)
• F10 key (Activate the menu bar in the active program)
• RIGHT ARROW (Open the next menu to the right, or open a submenu)
• LEFT ARROW (Open the next menu to the left, or close a submenu)
• F5 key (Update the active window)
• BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
• ESC (Cancel the current task)
• SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
• CTRL+SHIFT+ESC (Open Task Manager)
on Mar 15, 2008 | Microsoft Windows Vista Ultimate Edition
Cell Phones Logo
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
