Question about HP Pavilion dv1000 Notebook
HP dv2510eb Display Problem
Dear Tech Experts, I have HP dv2510eb laptop giving me display problems . I suspect the graphics card but I am not sure why ..It can display well for a few minutes after that the display turns multi-colored with mutiple duplicated screens . I switched from Ubuntu to Windows but the same problem.
Experts, What can I do with this laptop ? Help Me out Thank you in advance
Many thanks
    Scholar:
  • 162 Answers
Video problem. Could be an easy fix, could be something loose like the cable. But you would need a professional to look at it.
Posted on Jul 25, 2008
Why some graphic motherboard in Graphic card port disply came but in normal display not came
Difficult to understand your question.
If an external monitor works then the problem is Cheapest to most expensive:
MB to Power inverter cable is bad (No light to board) to check shine a flash light at you screen if still black not this
Power inverter is bad
Cable from Motherboard to Laptop screen is bad flashing on wiggle test will show flickering image
Display panel on laptop is bad if this is the case replace the Display cable/ Inverter power cable/LCD
this may still not solve the problem if you are not sure take to a local repair shop
Mar 30, 2013 | AMD 486542-001 - HP Pavilion DV7 Series...
I cannot project to second screen
http://h10025.www1.hp.com/ewfrf/wc/product?product=1817059&lc=en&cc=us&dlc=en&lang=en&cc=us
1) Laptop OFF, external display OFF, connect the external display to the laptop.
Turn the external display on.
Turn the laptop on.
There are at least THREE -> display options available.
1) Internal monitor of laptop ONLY'
2) Internal monitor of laptop and external display
3) External display ONLY
Hold the Fn key down, and tap on the F4 key once.
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
No internal monitor, and not external display also, means problems with the graphics chipset. May be one of the HP/Compaq models, that has problems with the graphics chipset overheating.
Due to a poor cooling design for the graphics chipset.
Graphics chipset repeatedly overheats, and softens the solder connections of the graphics chipset to motherboard.
(BGA surface mount)
Laptop is turned off, and cools down. Solder connections (Solder joints), re-solidify. This causes Cold solder joints.
Remedy in this case is to reflow the graphics chipset, and add more cooling surface, to the small metal plate attached to the Cooling Tube, that sits on the graphics chipset.
There are two Fan/Heatsink Assemblies offered. (Thermal Module)
1) One is for models that have UMA motherboards.
[ Unified Memory Architecture.
A fancy way of stating the graphics memory is part of the System Resources. The Processor and Ram Memory.
Two other terms used are Integrated Graphics, or OnBoard Graphics.
ON the motherBOARD ]
HP 430463-001 part number,
http://www.lapzone.com/servlet/the-16238/430463-dsh-001-HP-Heatsink-&/Detail
BING!
It's also used for the HP Pavilion dv2000 series, which DOES have a problem with graphics chipset cooling.
Look at the photo of the HP 430463-001, and at the Black round Fan Assembly.
Look to the left at the copper Cooling Tube. See that triangle shaped area that sticks out? This tiny surface area is what cools the graphics chipset.
SERIOUSLY inadequate!
(The Processor sits under that black square at the top, that has a smaller square hole in it. Four screws surround it.
{ You are looking at a Top View of the Thermal Module )
2) The second Thermal Module offered is for motherboards that has discrete graphics.
HP 417081-001,
http://www.ebay.com/itm/HP-Pavilion-DV2000-Heatsink-Cooling-Fan-417081-001-/160603422510
This time a Bottom view is shown.
Do you see a difference shari_n?
No? Neither do I!
Here is one tech's solution for this. This is for reference ONLY.
Not advertising for tech, nor website,
http://www.youtube.com/watch?v=PhxOVh2sbl8
This gives you more information on the BGA surface mount, using a BGA Rework Station,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down towards the bottom, click on the red -
Take a few minutes to view the IR 650 demo video
HP Support > Service Manual (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=1817059&
Click on -
Compaq Presario V3000 Maintenance and Service Guide
(Allow up to 30 seconds for the first page to come up)
Regards,
joecoolvette
Oct 21, 2012 | HP Compaq for Presario V3000 Motherboard
Display problem
It might be that the problem is within the display either Graphic Card or the LCD the best thing you can do is to call Lenovo Tech Support Dept check if you still have a warranty for Depot so that you can send it to the depot for repair via FEDEX free of cost
Lenovo Tech Support: 1-877-4536686
Thanks for using Fixya
Jul 29, 2010 | Lenovo IdeaPad Y510 Notebook
The display on my HP zd8000 is messed up... i suspect a damaged ati radeon video card .. is the graphics card removable? where is the graphics card located?
Well needs to replace the NB's Motherboard which will cost you around $430 with hp or Can get a new Nb with Win 7 O/S and Advanced video graphics at a price around $450
Feb 02, 2010 | HP Pavilion zd8000 Notebook
Display on HP DV6000 is scrambled.
Reseat the LCD cable on the laptop end and also behind the LCD panel. Since it working on external monitor the graphic card is working fine.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
Your problem is the screen itself, sounds like your graphics chip is fine by being able to use an external monitor. Change out the display, but also check the flat data cable on the back of the screen and make sure it just didn't slip out of the socket.
Error beeping 1 long beep follow by 2 shorts beeps
i AM A LAPTOP REPAIR TECHNICIAN.AND I HAVE SEEN THIS ISSUE WITH HP MODELS RANGING FROM DV2000, 6000 AND 9000 RANGE. THE PROBLEM IS WITH THE ON BOARD NVIDIA GRAPHICS CHIP. THE ONLY WAY TO REPAIR IS TO REPLACE THE MOTHERBOARD.HP HAVE EXTENDED THE WARRENTY WITH THESE MODELS FOR AN EXTRA 6 MONTHS. BUT THIS RANGE OF LAPTOPS ARE A COMPLETE MESS. WIRELESS PROBLEMS ARE ALSO VERY FREQUENT.OF ALL THESE MACHINES THAT HAVE COME IN TO MY SHOP FOR REPAIR , THERE WAS ONLY ONE THAT I CAN REMEMBER THAT HAD A RAM PROBLEM. THE REST HAVE ON BOARD GRAPHICS PROBLEMS.
Oct 12, 2008 | HP Pavilion dv6000z Notebook
Problem with display card
I think its overheating You need to buy a can of compressed air from ' **** Smith or similar store "
remove plates etc from underneath laptop and blow out also check exhaust port for fan is clear
Oct 03, 2008 | Compaq (292994-001) (Refurbished) (2 MB)...
Display Driver Issues
do one thing.just call up your hp customer care ask the exact website for updating your bios.also update the drivers of ur intel graphics card. most high end online games need latest nvidia graphics card.You made a mistake by purchasing intel graphics card.
Jun 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv1000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
