Question about Parsons QuickVerse 7 Essentials (fe11044) for PC
Quick verse 7
Wont install on my upgraded XP oper. sys. which was once windows 98se
  • Anonymous Mar 15, 2014
    Please teach me how to install Quich verse 7 to Windows 8.
Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…
Posted on Aug 17, 2008
I found a similar problem with Quikverse 7 under XP. It could find the books it had installed on the hard drive, but was failing to recognise the books on the CD, although it knew they were there.
This was solved using the Library Management tool as above. I basically installed all the books onto the hard drive and now I can use them all as I did under Win 98.
Thanks, I've wondered for a while how to fix this.
Willie
Posted on Sep 04, 2008
  • 50 Answers
Try installing it in safe mode. Restart your computer and tap f8 as it is booting, then select safe mode.
Posted on Jul 11, 2008
Cannot install my Quick Verse Version 5 on my new Dell computer with Windows 7. Message says it is incompatible with Windows 7. Any suggestions?
Good day,
Before Double clicking the Setup icon on installing the Software. Right click the Setup Icon and Choose "Run Compatibility Mode" and Choose windows XP.
Tnx
Aug 18, 2011 | Parsons QuickVerse 2005 Expanded Edition...
I want to install Quick verse 7 on my new windows 7 computer. What special instructions do I need? Bruce
The system requirements of this software are Windows 95 / 98 / ME / NT / 2000 / XP only. but their are new version of Quick verse 7 that are compatible in window 7 visit this link..
http://www.quickverse.com/Shopfiles/product_details.asp?ID=41244
Apr 25, 2011 | Parsons QuickVerse 7 Essentials (fe11044)...
I cannot open the file downloaded from Microsoft to enable me to use the help file. I am trying to find the meaning of the symbol (underline circle) appearing in text as a superscript. This is in...
I Think Your problem no in QuickVerse 8 Deluxe, but on Windows 7.
1. Software for XP, few can installed on Windows 7 -> i think you use Application for XP
2. Usually windows 7 must be Pacht-ing for use windows XP Application
3. May be you can Try install -> on software -> Right Click -> Run As Administrator "you Must enable Administrator befor".
Feb 19, 2011 | IMSI QuickVerse 8 Deluxe (QUICKVERS8E) for...
Sir i have aspire 4738z p6100 with windows 7.can i use xp operating sys.
Yes you can use windows xp thereshall be no problems.
In order to use windows xp you have 2 options,
1. Install windows XP on your computer ( that will remove windows 7)
2. You can make it a dual boot where you can have both the operating systems. (win 7 amd win xp)
To install windows xp you will need a windows xp os disc with a valid license key with the help of the disc you can install windows xp.
Nov 03, 2010 | Acer Computers & Internet
Had windows vista on want to change it back to windows xp
foer that you should have a bootable windows xp cd and boot it from it and then reformate the hdd with quick formate. but before doing that make sure that the dat is backed up and you have all the drivers for windows XP. But instead of that I would suggest you to upgrade your sys. to windows 7.
best of luck.
Oct 27, 2009 | Maxtor Hard Drive
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
Any problems to upgrade from 6 to 7?
hello, and the anser is no it should'nt be a problem to run 7 with win xp even though you have 6 allready.
Mar 30, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Pc virus
yes
install avast, quick heal and symantec with update one bye one.
scan your sys in safe mode.
note:install this anti scan and remove it one bye one.
if your sys have two anti then your sys is slow dowwwwwwwwwn.
Mar 26, 2008 | Microsoft Windows XP Professional for PC
Broad Band internet connection under WINDOWS 98SE.
i think it is because 98se is not compatible with broadband or wireless, you know what i mean, if i were you i would upgrade that OS to xp, very cheap these days
hope this helps
Dec 06, 2007 | Microsoft Windows 98 for PC
Parsons QuickVerse 7 Essentials (fe11044) for PC Logo
854 people viewed this question
Top Parsons Computers & Internet Experts
tdk1988
Thomas Perkins
Thomas Perkins
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
