Question about Zebra Z4Mplus Label Printer
Label size I need your help! we are trying to print from a Z4mplus printer, we used L =6 in x W = 4in, label, we are trying to use a L = 1 3/8 x W = 4? how do we adjust the printer not to skip two labels before printing??
    President:
  • 2,976 Answers
Set the label size in the label program and then calibrate the printer.
Posted on Feb 05, 2009
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
Oct 28, 2015 | Zebra Z4Mplus Label Printer
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
I created a new label layout in Filemaker pro to print a 4" x 6" label. When I print this label on the Zebra LP 2844 printer it prints fine. If I try to print it on the Z4MPlus it enlarges the print and...
The easiest solution would be to create a new label layout in FileMaker specific for that printer that can be used when printing to that printer which would solve that problem.
The issue with the size being enlarged is most likely with the printer driver and not the FileMaker software so that is where I would look around to see if there is a scaling setting, or some other setting that needs to be corrected in the driver/page setup area for that printer.
I hope I've done a good job answering your question. I am a FileMaker 7 expert (and 8, 9, and 10 as well); if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Aug 13, 2009 | Zebra Z4Mplus Label Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Print problem
You should make sure you have the label program set for the same size label you are printing and calibrate the printer before you start a roll.
Feb 05, 2009 | Zebra Z4Mplus Label Printer
Z4Mplus doesn't save configuration
I had the same issue.
I'm using the seagull scientific drivers.
It turns out that the printer did not react well to changes made to it through the software.
I deleted the printer and added it again.
I made all my changes immediately through the software (creating a custom label size of 4in x 1in and portrait 180)
My print width setting on the printer is still 099 6/8 but everything prints fine.
Apr 17, 2008 | Zebra Z4Mplus Label Printer
Label Printing
Forward length matters in Label size detection. Width is just secondary. Length should be same for both. Else no, you have to had separate roll for each label size.
If the labels are same in length then there might be achance using Label Software that supports your printer.
Jan 24, 2008 | Zebra Z4Mplus Label Printer
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
277 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
