Question about Dryers
KitchenAid Superba dryer(electric) will not run. I have power. All I hear is what sounds like the timer running.
  • 2 more comments
  • jkkmt Nov 24, 2008
    Kitchenaid Superba dryer model #KEYS850LQ0 (Electric). When you set the timer, you can hear it clicking, but when you push the button to start the dryer, it does not run (but the timer still clicks)
  • twty Dec 25, 2008
    What was the solution to this problem - "timer ticking but it wont start"?
  • dsmith3733 Dec 26, 2008
    I have the same problem. I can find a source for the part, but can anyone give me directions on how to replace the thermal fuse? (in words of one syllable, please - I'm new to this)
    thanks,
  • cfensch Apr 20, 2009
    I had this EXACT problem on my KitchenAid KEYE777BWH0 dryer. I tried the thermal fuse and voila! It worked like a charm! $15 for the fuse (purchased locally) and I was up and running again! THANK YOU so much for this advice! I really didn't want to spend $150 for a service call on a 14-year-old dryer, and was seriously considering a new one. Up until this problem, the dryer had worked flawlessly. It's been a great one. Now I'm off to get a vent brush! THANKS EVERYONE!
  • 254 Answers
You probably have a bad thermal fuse, small white two teminal fuse on the blower housing.
Posted on Jul 11, 2008
My dryer shuts off when it gets hot. Can you tell me what is whrong
Posted on Aug 12, 2011
A new thermal fuse worked! Thanks so much!
Posted on Apr 20, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Kitchenaid Model Keys750GQ0 light come on and the timer running push the door switch light turn off check power fine at 220V Please help Thanks in advent
Unplug dryer and try bypassing the thermal fuse by taping the two wires together and plug back in and try to start. If starts replace thermal fuse.
Sep 21, 2011 | KitchenAid KEYS750LQ Electric Dryer
I have a kitchen aid dryer SUPERBA electric dryer. It stopped drying. still runs ok but no heat. Checket the Element . looks fine . what could be the reason.?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
Kitchenaid Superba Dryer also stopped working (3 years old)
Yes it is, you can bypass it for testing purposes only, also clean out your vent too the outside it is probably clogged that is what usually blows them out.
Jul 24, 2008 | Dryers
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Fridge does get cold
Sounds like the motor starter/capacitor may be faulty. How long does the compressor run for? Do you hear a clicking every few minutes from the compressor? If a power surge fried the defrost timer that too could give similar results.
Dec 17, 2006 | KitchenAid Superba KSCS23IN Side by Side...
Dryers Logo
1,608 people viewed this question
Top Dryers Experts
