Question about Sony Walkman D-NE518CK Personal CD Player
Turn off beep
I have forgotten how to turn off the beep, that happens when I touch any
button. I cannot find the orig. instructioin.
Hold down the stop button while inserting the batteries.
Posted on Jan 07, 2009
My ER-A410 cash register reads not assigned
usually a reset button underneath it were on ours not necessarily same model
Mar 22, 2015 | Retail Supplies
HAVE FORGOTTEN OUR PASSWORD FOR OUR IPOD TOUCH AND HAVE TRIED RESTORING THE IPOD BUT THIS NOT WORKING.
Resoting a passcode-locked iPor touch over iTunes will never work. iTunes will only tell you to unlock the passcode first before you can do anything on it. The only trick here is to put the you iPod touch to DFU mode in order fot the restore to proceed. And to do that, here are the steps:
  1. Plug/connect your device to a computer (PC or Mac)
  2. Turn it OFF
  3. Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
  4. Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
  5. Open iTunes and restore your device.
Warning: Restoring will delete all data on your device but this is the only way for you to recover it.
If you don't get it at first, try holding the buttons for lesser time or see the other procedures and some screenshots on my tip (link below):
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Mar 27, 2011 | Apple iPod touch
My oven beeps sometimes after use there is no code showing when this happens. the beeping can last for 15 min. sometimes.
most likely you have a bad touch pad the unit has a faulty kep on the touch pad and is going to require a new touch pad...you may be able to turn the power off at the breaker for a few minutes and while off run your hand over the touch pad buttons firmly ..you may luck out and free the stuck one up but most likely you are going to need a new touch pad with the ribbon cable conection...
Jan 05, 2011 | Thermador CM302U Electric Double Oven
My ipod touch is disabled after a few failed attempts at my forgotten password and now it says disabled connect to itunes but it says unlock before it will connect it what do i do
This is how you can recover your device:
  2. Turn it OFF
Nov 04, 2010 | Apple iPod touch
My ipod touch is disabled as iv forgotten my password
Fix it by doing the following:
  2. Turn it OFF
If you don't get it at first, try holding the buttons for lesser time or see the other procedures on my tip (link below):
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Aug 27, 2010 | Apple iPod touch
I have forgotten the 4 digit screen code and i can't get to the first computer the ipod sync with.
Do this to proceed with the sync:
  2. Turn it OFF
May 21, 2010 | Apple iPod touch
I forgot my pin and I need to unlock it
You have to go to the orig location you programmed your number. It uses the coordinates of that location in memory as a "Home" See below.
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location.
To set the Garmin Lock on the device:
  1. From the Main Menu, touch the Wrench (Tools) icon.
  2. Touch Settings.
  3. Touch Security. (you may need to touch the down arrow button)
  4. Touch the tab labeled Off next to the Garmin Lock heading.
  5. The nuvi will prompt you to enter a four-digit pin number.
  6. Enter a four-digit code as your pin.
  7. Re-enter the four-digit pin.
  8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
  9. Set the 'Security Location' by touching Set.
The Garmin Lock has now been turned On.
Dec 25, 2009 | Garmin nuvi 260W GPS Receiver
I recieve a garmin as a gift @ it now has a code lock on it how can i unlock my garmin 260
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location. (where it was orig programmed)
  2. Touch Settings.
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
Playstion 3 Wont turn on
try to turn it on by inserting a disc....
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Xerox 5665 beeping for all functions
  1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Common Settings] button. The Common Settings screen will be displayed.
  5. Select the [Audio Tones] button.
  6. Select the required option from the list, and then select the [Change Settings] button.
  7. Select the [Save] button to save the settings.
  8. Select the [Close] button several times, and then select the [Exit] button to exit.
Jul 03, 2008 | Xerox 5665 Copier
Sony Walkman D-NE518CK Personal CD Player Logo
391 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
