Question about Refrigerators
GE Side by Side Fridge Freezer
My fridge / freezer goes into defrost and all products inside go soft. I have read some other posts and believe that I may need to adjust the defrost timer. Where is it on this model and how do i adjust it.
Many Thanks
    President:
  • 1,314 Answers
Defrost timers are not adjustable i would look more for a fault in the cold controls not cutting in at the right temp is this an electronic control model if it is pull the cover off the back of the unit on the left hand freezer side and inspect the mother board for any burned resisters
Posted on Jul 12, 2008
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE mongram side-by-side freezer/fridge. Just notices today freezer temp was 18 F and fridge was 40 F. In 1 hr they have both gpne up a few degrees more. Please tell me what is going on. Ice-cream...
I believe your defrost heater inside the back of the freezer compartment rear panel has burned out. Unplug remove the panel and get a look at the defrost heater. If burned out it will be easy to spot because yours has a glass tube around the heating element inside. Let me know what you find, Thanks, Sea Breeze
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
GE Profile side by side freezer not working at all. Fridge ok.
Is the fridge side working? If not try turning the defrost timer dial until it clicks. If it now goes you need to test the defrost circuit as there's still a fault but it'll go for 12 hours untill it trys to do another D'frost. If this doesn't work try bypassing the thermostat. cheers
May 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Fridge not cooling
Make sure that the light in the ref side is not staying on when the door is closed. Could have a bad door switch. Probably have a defrost problem in the freezer. Check to see if there is a lot of frost build up on the inside/back of the freezer. If there is then you have a bad heater or defrost thermostat or a bad timer. Also another possibility is make sure the freezer fan is working. If there is no circulation of air then the fresh food side will get warm. Then replace evaporator fan motor.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Temperature in refrigerator is too low
The solution is that the air flow from freezer to fridge must be reduced at the point where air goes into crisper drawers. There is a vent, remove cover, insert 'sponge', replace vent cover.
Nov 26, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
