Question about HP LaserJet 3055 All-In-One Printer
HP 3055 Laser Printer. How Do I clear?
I had turned off printer when it was printing an excess amount and now a light flashes "No Paper pickup"
  • sameerahmed Oct 14, 2008
    first my printer was showing paper jam , i had remove paper and I had turned off printer when printer starts it now showing a light flashes "No Paper pickup"
Posted on Oct 14, 2008
Roller to be replace
Posted on Sep 28, 2008
  • james61 Sep 28, 2008
    if you know there are heating element roller and right next to it it has a black roller with plastick film on it it looks like that film is torn and when yo print it paper getting sturk in it
  • 61 Answers
Open the printer remove toner cartage and see inside the any paper are jamed in printer remove the paper and if the problem is not solved the contact me i will told you what to do
Posted on Jul 24, 2008
How can i clear buffer on hp 3020 all in one laser
Why not let it complete remainder printing after cancelling the job.
You may also pause printing, remove most paper from paper trays so that it run out of paper then then power cycle the printer.
Nov 18, 2013 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055. after printing labels, a few at a time, over and over. The label paper is no longer white, it is gray. The label paper picks up dirt from the printer.
Labels are a problem, as they really kill the printer, if they come off. It sounds like your issue may be that you need LASER labels, which are less affected by the temperature of the laser cure process.
Apr 01, 2011 | HP LaserJet 3055 All-In-One Printer
How to fix the hp laser jet 3055? Is not printing... looks and sounds like is not grabing the paper sounds like the turning wheels are turning but not grabing paper..help
Try gently scrubbing the rollers with a lint free damp cloth.
Make sure that the paper is good(not warped).
Make sure that the paper is pushed back far enough to meet the roller.
Dec 21, 2010 | HP LaserJet 3055 All-In-One Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
No paper pick up
Add more paper to the try, alot of laser printer requires alot of paper before you can get it to quite down.
Nov 24, 2009 | HP LaserJet 3055 All-In-One Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
ADF Does not show paper is loaded. If slide the document under the pickup roller in the ADF it will show document loaded but when I hit copy a "pickup roller error" is displayed. What would cuase...
Sometimes paper dust, and bits of paper clog the paper sensor, you can try using a can of compressed air to blow the sensor clear. use a flash light and locate the pickup rollers, and sensor. Clean both, if you can reach them. If they are clear, then the sensor might have stopped working. Check your warranty.
www.lhsjrinc.services.officelive.com
May 07, 2009 | HP LaserJet 3055 All-In-One Printer
No paper pickup
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Jan 22, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
242 people viewed this question
Ben Johnson
