Nordic Track NordicTrack T7 si Treadmill Logo
Posted on Jan 08, 2011
My console reads checksum: fail. I have tried unplugging, resetting and nothing works. The display lights up but when I put the key back in it brings back the checksum: fail reading.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1188
Points
Have the same problem with a Nordic Track Eliptical. Sorry, I have no solution. What solved yours?
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
God bless you
Can you advise please
reset the machine make this: God bless you
    • 3
    • 4
    • 2
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
    • 3
    • 4
    • 2
Factory reset code
follow this instruction and reset. God bless you
need replacing, or move on to the next step.
  • 2
    console. Usually the button is large enough to trigger with a pencil
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    I am getting an error on the console of my Proform XP Treadmill that reads: checksum: fail...what does this mean and how can I fix this?
    The Display Console is the brain center of the Treadmill. .. Checksum Error Xxxx . Rom failure to due a possible cause 8Vdc. by short circuit inside..Faulty display consolel PCB.
    Since the treadmill is a computer has the same components like a PC.
    Treadmill is plugged, lights are on but does not work
    The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
    Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
    Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
    DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
    2answers
    Blank screen after switching hp nx7000 on
    You will find useful information and BIOS downloads here:
    Notebook Does Not Startup or Boot Displaying a Blank Screen
    BIOS update
    Try the first link first. Update the BIOS after carefully reading all the instructions.
    2helpful
    2answers
    Km-2030 Checksum error f1
    my copier is displaying error code 100, whats the problem km 2030
    The display lights are all solid and nothing happens when you press on the keys. I have a GE Sensor Microwave. I bought it in September of this year. Came home from work one day, went to heat something up...
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
    You may have a failed keypad.
    18helpful
    5answers
    Bad BIOS checksum.... CMOS bad checksum errors
    BOOT BLOCK COMPATIBLE VERSION VER .005
    BAD BIOS CHECKSUM
    CHECKING FOR CD ROM
    READING FILE "P5SD2VM.ROM"
    NO CD-ROM FOUND
    CHECKING FOR FLOPPY DISK
    NO FLOPPY DISK FOUND
    Does someone already fix this problem??????
    Top Nordic Track Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    vince
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
