Question about Samsung RS2630SH Side by Side Refrigerator
Leaking icemaker I replaced the icemaker unit a few weeks ago. It now drips on the ejected ice, making it clump together. I have taken it out and reinstalled it. I can't find the source.
  • 89 Answers
What was the orginal problem with IM? If same as listed above you need to replace the water valve...
Goodluck, Brian
**** Water valve is located behind the refrigerator and bedind the cardboard at bottom...Hint; It is blue!
Posted on Jul 14, 2008
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and now will not work automatically. It will work...
Good day!!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Hope this information will be helpful..
Thanks for using fixya...
Aug 29, 2011 | GE Refrigerators
I have a 12 year old Sub Zero model 624. The ice maker has completely stopped producing ice. And actually, when opening things up we can see ice cubes have formed but they just haven't dumped into the...
This is the procedure but yours seems to be a faulty Icemaker and needs to be replaced since your freezer is cold enough to make ice rapidly.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Sub-Zero 642
Water leaking in ice cube tray - makes chunks of ice in ice container
Hello, Thank You for using FixYa. I will be helping you today.Are you sure water is leaking? This ice bucket is famous for all the ice clumping together! Some of the reasons are,Not using the ice dispenser enough,Crushed ice getting stuck in the ice chute door allowing warm air in to melt the ice,Ice door not closing all the way,Opening and closing the freezer door allot,But like mentioned before not using it every day is the main reason.You should remove the bucket every couple weeks and run hot water through it.If it ever gets stuck on the door you have to remove as much ice as possible and then use hot water to pour in there and catch the water out of the ice dispenser until it will break free.There are allot of service calls for this and never have i seen any icemaker that leaks if it is you have to replace it.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool Gold® GC5NHAXSY
Ice maker is not working and soft ice is forming around the area where the opening of the ice dispenser
Most of the time where they are making ice at the fill tube point the icemaker water valve in the back of the unit is leaking / dripping water past the valve / diaphram seat and it will have to be replaced. You can prove this by turning off the icemaker and then pulling the tube off the back of the unit and placing it into a bucket over night. If your sure the icemaker is off and there is water in the bucket the next morning the water valve is bad.
Now as for that ice in the icemaker fill tube... you can use a hand held hair dryer to defrost it once you change the water valve. I just changed my own water valve on a maytag less than 2 weeks ago that was doing the same thing. (Ice in fill hole and tube) It is working like a champ now.
A GE replacement dual outlet water valve:
http://www.appliancepartspros.com/Appliance-Parts/GE-Dual-water-inlet-valve-kit-item-number-AP3672839.aspx
(Make sure to use your model number when seeking the correct replacement see "useable on model list" bottom of the page)
Thanks for choosing FixYa.
Kelly
Aug 29, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice from icemaker melts together in one big clump. only able to use the most recently made cubes.
look for water over flling the ice tray . may need leveling / also the water valve may be leaking through. if so replace it .. mm
Aug 14, 2010 | Frigidaire FRT22TSE
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Oct 11, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
128 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
