Question about HP Compaq Presario V2000 Notebook
Connecting my laptop to tv
Hi i hope some one can help i have a hp compaq 6720s and i want to connect it to my tv my tvs brand new so should be up to date with connections etc
thanx sarah
  • Anonymous Apr 27, 2009
    6720s has not SVideo Port, another solution please?
    Sergeant:
  • 264 Answers
The first thing you should check is that whether your Notebook has a SVideo Port or not.
If Yes than you need the Svideo Cable which you can use to connect the computer to the TV.
Once that is done, In order to shift the Display from the notebook you need to use the shortcut. (Function Key + F2)
Note : Diff computer may have different shortcuts to shift the display.
It could be (Function key + F4 ) on HP
Hope this helps
Regards
Sammy
Posted on Jul 11, 2008
My dvd rom for compaq 6720s wont eject
make sure that the dvd rom is getting enough consistent power test all leads that are attached to the dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps
Dec 11, 2010 | HP Compaq 6720s PC Notebook
HP COMPAQ 6720s wireless radio is OFF and can't be switched ON.
Please refer to the following article for some tips on how to troubleshoot wireless connectivity issues:
http://www.fixya.com/support/r6556655-troubleshooting_laptop_wifi_connectivity
Dec 07, 2010 | HP Compaq 6720s Laptop
I've tried entering the product key on my new compaq 6720s and it says it is invalid, what can i do?
The only real solution would be to contact Microsoft and tell them your key isn't working with your brand new computer. They "might" be able to help you or probably just tell you to return the computer or buy a valid copy of Windows in worst case instance.
Aug 21, 2010 | HP Compaq 6720s PC Notebook
The drivers for this device are not installed(Code 28) for hp compaq 6720s
Hi:
Your problem doesn't state what driver or device isn't working on your HP compaq 6720s, but all drivers for your laptop can be downloaded from www.hp.com for free. click on the support tab, type in your model number and you can download all of them.!
Aug 20, 2010 | HP Compaq 6720s Notebook
I have a laptop which is hp widows vista,compaq 6720s. my little boy went on it and the screen side is has crack and doesn't work. what should i do HOW MUCH DOES IT COST TO FIX IT
The replacement panels for the Compaq 6720s range between $85.00 USD and $110.00 USD depending on where you order them from. The replacement is a relatively easy procedure, but I don't recommend it for a first-time novice do-it-yourselfer.
Here are links to some places where you can order the display panel:
http://www.blisscomputers.net/hp-compaq-6720s-laptop-lcd-screen-15-4-wxga-glossy-ccfl.aspx
http://www.screencountry.com/index.php?section=products&model=HP%20COMPAQ%206720S&brand=HP-Compaq
http://www.r3electronics.com/index.php?option=com_virtuemart&Itemid=1&page=shop.product_details&flypage=flypage.tpl&product_id=1147&category_id=38
Now the good news is you can still use your laptop if you have an external monitor. You can use the appropriate "Fn" key combination to switch your display output to the external device. I believe for the Compaq 6720 is the "Fn" key & the "F4" key. Connect the external monitor then power on your machine, Press the Fn and F4 key simultaneously until you get the display showing on the external device.
One more thing, you will need to go set the laptop to not do anything when the lid is closed. You can do this via Start -> Control Panel -> Power Settings. Change the custom power settings for both "A/C" Power and "Battery Power" to "do nothing" when the lid is closed. By doing so, you can close the laptop lid without shutting off the computer. Of course you will need to add an external mouse and keyboard to continue using the computer, but by following these instructions, you can basically use the laptop, even with a damaged screen, pretty much the same way you would use a desktop. The portability is lost, but the function is retained until you can have a new display panel installed.
Hope this helps FixYa! Please take some time to leave some feedback and a testimonial if you found this information helpful.
May 08, 2010 | HP Computers & Internet
How do i reboot my hp compaq 6720s laptop i have no disk
rebooting is just restarting.if you want to get new, reset by recovery partision think you press F11.
hope this helps.
Apr 28, 2010 | HP Compaq 6720s Laptop
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
Connecting creative 4.1 speakers with my HP Compaq 6720s laptop
Go 4 setting of audio device in ur laptop.
n check is there 4.1 speaker system is available r not.
Then u can fix ur 4.1 creative to ur laptop.
Aug 01, 2008 | HP Smart Buy Notebook
HP Compaq Presario V2000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
