Question about Brother Office Equipment & Supplies
Setup must have failed cannot print on brother mfc 6800 although I can scan
    Sergeant:
  • 264 Answers
It seems that somehow the installation of the software did not work fine.
Either use the disk to reinstall the software OR download the same from the Brother Support website to install the same.
It surely is a software issue.
Hope this helps
Regards
Sammy
Posted on Jul 11, 2008
How to cancel print job in brother's mfc 6800 printer?
open printers left click on printer and cancle aii printing jobs. if this don't work delete printer and reinstall
Aug 31, 2013 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 won't send scan results to iMac. The scan function appears to work, although nothing appears when using iPhoto or Picass for Mac. I am using Mac OX 10.6.5
Hi
I had the same problem. I knew the scan function was not broken because I could use it with my old PowerMacG4. But no go with the new Intel iMac, and no amount of driver updating or other OS fiddling solved anything.
I luckily found another MFC-6800 to test. And to my surprise scanning is working, and printing is much improved (no more "offline printer" when it's clearly online). The difference between the two: firmware version. My MFC is dated from 2001, while the other one is from 2004. For the date see the label behind the machine.
Now, why does scanning work on my old PowerMac G4? Apple probably changed something in the Intel drivers or the USB circuitry, or Brother didn't adhere to proper standards in 2001. Or it may be as stupid as an inability of the older Brother board/firmware to deal with USB 2 levels, even throttled down to USB 1.1. Who knows? Anyway I'm in contact with Brother and hope to get a way to upgrade the firmware in my printer.
Did you try scanning with Graphic Converter? Some Adobe products need updates to properly scan in Snow Leopard.
Hope this help.
Dec 13, 2010 | Brother MFC 6800 All-In-One Laser Printer
I can't find software for Brother MFC-6800 printer for Vista....I can print only..I can't find scan, copy software for vista
The OS has a built-in driver that should automatically install when the USB cable is connected. Check Windows Update for new and optional updates if you don't see the printer appear. If you use a bi-directional parallel cable (with the computer properly set up), use the Printer Wizard and then the Add Device Wizard (IIRC). The scanner won't work over the network.
Try using one of the programs built into Windows: Windows Fax and Scan (New Scan), Paint (File > Import from Camera or Scanner > New Scan) or Photo Gallery to launch a scan. Alternatively, get a third-party software option (Paperport, for example).
Go here: http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/dlf/download_top.html?reg=us&c=us_ot&lang=en&prod=mfc6800_us to get a utility to improve the scan resolution.
I hope this helps.
(Scanner problems can often be resolved with a new data cable and a direct connection between the unit and the computer. This assumes that the scanner is unlocked (for those with a transport lock) and that the unit is properly lighting up and the scanner is moving freely.)
Nov 22, 2010 | Brother MFC 6800 All-In-One Laser Printer
My brother mfc 6800 is printing pale
In the menu of this machine there is an ecology section, make sure toner save is turnned off.
Feb 10, 2010 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 printing all black.
more likely the scan lamp, does it shine when doing a copy of the sky?
Dec 12, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
