Question about Ricoh Aficio 1035 Copier
Aficio 1035 ps
What is error code SC726?
  • Ricoh Master
  • 2,794 Answers
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Posted on Jul 12, 2008
  • 162 Answers
Finisher shift tray 1 lift motor error
Tray shift does not finish within the
specified time after the shift motor
turned on, or the stack height sensor
does not activate within the specified
time after the shift tray lift motor turned
on.
Shift motor defective or overloaded
Shift tray lift motor defective or
overloaded
Inspect that the tray of exit this in its position. Sometimes the plastic supports become broken and it does not touch the sensor of race aim.
Posted on Nov 15, 2009
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
What does 'SC726 Problem with finisher' mean on a ricoh aficio 2022
sc726 is a finisher lift motor error. The lift motor could be bad, or the sensor that detects where the motor is might be bad. It could also be an overload problem, if something is in the way preventing the shift tray from lifting.
Aug 12, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
Feb 21, 2011 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Nov 02, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Jul 31, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
266 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
