Question about Dishwashers
Problem with my sears model 665 dishwasher. It will intermittantly halt and I've replaced the electronic control card with no help. Also, the door latch is OK
No water is geting inside of the dishwasher
Posted on Jul 11, 2008
Kenmore 665 dishwasher problems
Check the door latch and switches.
Aug 22, 2014 | Kenmore Dishwashers
Kenmore DW model #665 16023403 will not turn on. There is power to the DW but the panel does not light up. Checked circuit breaker. Door tightly shut and latches. Just 3 yrs old. Would love to fix myself....
The electronic control panel should be replaced and cost about $240. It is easy to remove and replaced --- pull and plug like a standard elect plug, only its flat.
This definitely works.
Sep 04, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
Manual for sears dishwasher item MOD#1440902214409000
I am not sure if you have got the correct model number.
Sears dishwashers are usually of the following makes - Kenmore, Maytag, Kithchen Aid, Whirlpool and the model number would be something like 665.xxxxxx
Can you please change the model number and post a comment.
Nov 20, 2010 | Dishwashers
Sears model 665 ultra dishwasher has no power,breaker not blown but nothing works,no lights nothing
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 04, 2010 | Kenmore Dishwashers
I have model number KUD 101TJBL0. I have spent about 300.00 on repairs. It keeps blowing the thermal fuse. I have had it replaced sev. times. My repair man has given up on solving the problem. I did read...
This applies mainly to Kenmore Dishwashers with the model number 665.15835791 but also to any Whirlpool or Kenmore dishwasher with an electronic display. There are several possible trouble makers on this dishwasher that can cause this problem and we'll go through the most common ones.
1.Bad Door Latch Switches.
There 2 switches you can buy them from online vendors.
2. Blown Thermal Fuse
The thermal fuse is located in the control panel, called out as item #18 in this picture. You can check it with a simple continuity test. Or you can jumper it out to see if the dishwasher will start running normally. If it's bad,
http://www3.sears.com/Paul/Leadimage.asp?productTypeID=0130000&brandID=0582&modelDesc=DISHWASHER&modelNumber=66515835791&documentID=10058594&documentTypeID=PLDM&documentClassCode=PM&titleType=FRAME%20AND%20CONSOLE&titleID=00001&
3.Control board problems can stem from **** and noise in the dishwasher's electrical supply which make the electronics on the control board go flakey. This problem has been documented by Whirlpool in a tech memo (if your Kenmore model number begins with 665 then, yes, Whirlpool made your dishwasher). Or, it could just be a bad control board, plain n' simple.
The above one is a generic solution, also applicable for Kitchenaid Dishwashers.
The best online vendor as per user reviews :-
http://www.repairclinic.com
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
DO ACCEPT THE SOLUTION IF 100% SATISFIED.
Sep 18, 2009 | Dishwashers
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
