Question about GE WBVH6240F Front Load Washer
GE WBVH6240F The only thing that will work is the door locked light. Washer will not come on or even start a cycle. What is the problem and how do I fix it. THANKS
  • 725 Answers
Check the door lock it may have a bad connection will the door lock?
Posted on Sep 07, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Oct 13, 2009 | GE WBVH6240F Front Load Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Cleaned filter, washer still won't run
WasherMama,
I think they all start out that way - sort of a self diagnostic check on all its functions (lock, turn one way, turn the other, unlock) before it actually starts washing. After I wait a moment (or longer) it relocks the door and only then does the water start to run and the cycle begin.
I hope I'm not just stating the obvious.
Jun 10, 2008 | GE WBVH6240F Front Load Washer
GE WBVH6240F
I got the same problem...
Jun 01, 2008 | GE WBVH6240F Front Load Washer
Ge wbvh620f will not run
this is a good candidate for a premium solution, me thinks..
May 23, 2008 | GE WBVH6240F Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
425 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
