Question about Midland 75-822 40-Channels Handheld CB Radio
I recently purchaced 2 Midland CB radios and headsets to go on two motorcycles. When I use them I get excessive feedback. It appears that the metal motorcycle handlebars interfere with the rubber antenna. DO you know of any solution?
  • el_marc Nov 25, 2008
    Go to the J&M motorcycle audio website, they have all the hardware to make it work. Marcos
    Problem Solver:
  • 14 Answers
The problem is with the headsets, not the motorcycle. If the headsets are generic they may not have the proper mic connections. How do the radios work without the headsets?
Posted on Nov 05, 2008
I Want To Add Talk Back Mod To CB Radio
there is what is known as the Quick and Dirty way, to add talkback to almost any CB radio. You will need a 130 Ohm 1/4 watt resistor. Open the radio and find the two mounting points for the external speaker jack and PA audio jack, you will want to solder the resistor across from the Positive connection of the PA jack to the Ground connection for the External speaker jack. This will give you talkback, and eliminate any feedback when the microphone is held at a normal operating distance away, Just remember, (This could potentially damage your radio if done improperly, I will not be held liable for anything that you do to your radio.) However, when done correctly this is a perfectly safe modification, and will allow you to monitor your output audio, as it is being transmitted. You can adjust the size of the resistor to your liking, however, I do not recommend anything lower than 100 Ohm, as there will be more potetial for squealing/feedback.
Feb 20, 2014 | Midland Radio Midland 9001Z Citizen Band...
Midland Model 77-099 CB Transceiver Stuck on Channel 8, No feedback noise from speaker.
undo the mic from the connector and blow into the connector to clear out any dust then do the same with the radio end. no luck then get a multimeter and put the black end into the antenna connector center and with the red end touch all pins seperatly to check for any kind of reading to confirm its not the radio.open the mic and do the same with the wires in it.unless you have knowledge of electronics you shaould not go any furtherthan this.take it to a tech and let him check out the leds that control the switching.
Feb 02, 2013 | Midland 77-099 CB Radio
How can you talk to cb radios?
with another CB radio only. A midland 2 way radio is gmrs and is a much higher frequency then CB. not compatible.
Sep 25, 2009 | Midland LXT310 2-Way Radio
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Sep 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 38 pr27/97 cb
red to (+) , black wire goes to (-) on the battery, 50 Ohm Coax cable to an aerial mounted onto a flat horizontal metal ,so that the aerial is at 90 degrees to the flat metal its monted on. Adjust the aerial size to see a SWR less that 2
Jul 18, 2008 | Midland Radio Communications
Midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Aug 16, 2007 | Midland 75-785 Handheld CB Radio
Midland 75-822 40-Channels Handheld CB Radio Logo
180 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
