Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
Can't get sound to work
Not sure what device or drivers to select
    Sergeant:
  • 264 Answers
With very limited details provided by you, i have given the solution below.
1. Check for the connections and Speaker
2. Check if its mute/volume and sound control options.
3. Reinstall drivers
Under the Device Manager you have "Sound Videos and Game Controllers", you need to check for the audio drivers there.
Also if you have the CD for the Sound card or the Mother Board CD, Use that to install the drivers again.
Hope this helps
Regards
Sammy
Regards,
Sammy
Posted on Jul 11, 2008
Sound card in desktop pc stopped working recently
Which operating system ?
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volumeiconsystem select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is afree driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free.
or you might try cnet
http://download.cnet.com/2000-20_4.html
Just type in what you want or need be specific you might have to try a few times to get it right.
Tick in either the all software or the windows software box.
IE: Motherboard name sound drivers
for windows 7
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers.
Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software.
Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers.
Right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers.
Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker.
You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 25, 2014 | Computers & Internet
My sound doesnt work
Which operating system ?????
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume.
You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volumeiconsystem select adjust volume
from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity
dust causes static to build up in a computer
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
be updated.
If you computer came with a motherboard disk the drivers could be on it although
http://support.microsoft.com/kb/307918
troubleshoot sound problems in Windows XP
Nov 26, 2013 | Compaq Presario CQ56-115DX Laptop
My audio cannot work,no sounds
Desktop or Laptop ?? and operating system ??
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps. Laptop If your computer came with a motherboard disc the sound drivers could be on it
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 05, 2013 | Microsoft XP Computers & Internet
My soud is not working,ineed to instail sound drive it to be come
Jan 30, 2013 | Microsoft Windows 7 Ultimate for PC
Sound probablems
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Jan 15, 2013 | HP Pavilion Computers & Internet
Hi. My Computer Sound File is not working. i try everyThing. Help Please.
You didn't supply the eMachine model. Go to the eMachine support and drivers website and try to re-install the audio driver.
Jan 05, 2013 | eMachines Computers & Internet
Lost sound after installing windows 7 on my hp d530 sff pc
Jan 02, 2013 | HP Compaq d530 SFF PC Desktop
I installed windows 7 home premium; now the sound card, previously used with XP, will not work .
Dec 27, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
Sound can not work under win7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
hope this helps W7
Apr 30, 2012 | Computers & Internet
Sound does not work
check the audio connector ( color green ) if it is connected properly to audio port ( color green : beside the pink port ) .
Check if you have installed the drivers for the sound device.
Also, if you have the speaker configuration in your system, you can check it if it has just been muted.
make sure .
1. You installed the right driver properly
2. It is not muted .
3. Try to use another speaker, so that you can test if your speaker device is working .
if none of these works, then probably your audio device, doesnt work.
Aug 09, 2009 | Computers & Internet
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
120 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
