Computers & Internet Logo
Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidently spilled a drink on my laptop, I acted quickly and was able to save the components of it, but now my keys on my keyboard are sticky and stiff. I can not find my user manual and I need to know how to safely clean the keys. Please help.
Anonymous
Level 3:
President:
  • Master 2,246 Answers
  • Posted on Jan 08, 2011
Anonymous
Master
Level 3:
President:
Answers
2246
Questions
0
Helped
515234
Points
7384
Contact service center to clean it
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
tip
Cover Your Keyboard
Keep liquids away from laptops at all times. That rule often gets broken, of course, and accidents happen. Should that accident end up on your laptop's keyboard, however, you could end up with more than just a mess: Liquids that seep through your notebook's keys can fry its components. Protect your notebook from spills with a custom-built, plastic keyboard cover from ProtecT Laptop Covers..
on Dec 10, 2014 • Computers & Internet
1helpful
2answers
I use my computer for gaming and when i move around with the arrows they stick sometimes in one of the directions un til i tap that key again, is this common for the classic keyboard 200?
Logitech keyboards are excellent both in quality and longevity.
Make sure some sugary drink has not been spilled on the keyboard.
This will make the keys stick and repeat. I have had good luck with Dawn and warm soapy water. Just make sure the keyboard is completely dry before putting back into service. 1-2 weeks drying time. (IF you dunk and submerge. Only the most severe)
Never EVER dunk a laptop in water to clean the keyboard.
I know I know... but someone will try it. :)
Check to make sure the windows sticky keys are turned off.
Sounds like dirt or a soft drink is causing this repeating pattern you described.
2answers
My son has spilt coke on the laptop 1 key not working O
If you spill drinks on a keyboard, something is bound to break, and apparantly only the O key did... The only way to fix it is to get a new keyboard, I'm sorry. I hope this helps, Yannick.
2helpful
Spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Spill on laptop..how do I clean
ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
2answers
Acer laptop
Pop the enter key off (be gentle), then take a Q-tip with alcohol (rubbing not drinking) and clean the connector and the rubber riser. If the problem persists, the you will have to replace the keyboard.
Not all keys on keyboard work properly
Not likely, if the regular alphabet and numbers don't work then there is something sticky spilled under the keys.
you can remove the back and the membrane and wipe it clean. takes a bit of work.
Top Aspire Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
