I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay open so can not reset television. Any one with ideas as to what has gone wrong? Thanks
  • 1 more comment
  • ALEXA_1977 Oct 08, 2008
    Thanks
  • Anonymous Dec 07, 2008
    I have a Toshiba 37C3030D and suddenly DTV stopped working. ATV and other inputs are working fine, but I cannot reset TV because Main Configuration Menu disappears after 1 second.
  • mgiovy Jan 08, 2009
    Thanks
Thanks
Posted on Jan 12, 2011
Is this TV digital? I've lost channels since the change to digital from analogue
I doubt it has a digital tuner but the owner manual should show that or Google the model number.
Sep 03, 2012 | Toshiba 14DLV75 14 in. TV/DVD Combo
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No digital picture on digital TV
Are you getting a snowy picture, If so, you`re still on analogue. If you are on a digital channel with say no signal, you should get a blank screen with either a message saying no signal or a dot on the screen. Ian
Jul 24, 2009 | Sony Televison & Video
Unable to view digitial tv pictures but audio and analogue pictures work
If you have cable and a top of set box , it may be the problem. If you hook the cable direct to the set and still no digital ... then the TV could have a defective digital board. The tuner is on this board and the tuner gets both analog and digital signals.
Jul 11, 2008 | Sony Televison & Video
LN-R460D 46in, channels intermingled
are you using digital or terrestrial transmission? try fine tuning it...and hey, check the antenna direction, and also the wires...if the sockets are tight enuf and are correctly connected.
May 18, 2008 | Samsung LN-R460D 46 in. LCD Television
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
420 people viewed this question
Top Televison & Video Experts
Electro Med Services...
